Help with oil filter for Kawasaki fs481v
Georgia
The mower is used for commercial lawn care. I want to know which alternative oil filter I can run on this engine. preferably an oil filter with more capacity than the factory filter. Thanks
I am running a fram ultra 3614 on my kawasaki fr651v. The same filter should fit yours. A fram ultra 3600 would be a longer version. I have not run the 3600, as the shorter fram does all i need.
I use a ST3614 on my fr651V. not a commercial mower. Wix makes a replacement (wix 57035, same size as the factory) but it's pricey. Ultra or Napa Gold have the silicone valve if that matters.
Kawa filer was 49065-7007 if that helps. it does have the silicone valve. the auto filter are a little longer so check for room.
I use a Fram Tough Guard TG4967 on my Mother-in-law’s John Deere X475 with the Kawasaki FD671D engine in it. I could use the larger 3614, but just stuck with the stock size.
L8R,
Matt
