w230 Kawasaki factory vs wix
Arizona
I’ll be using wix or Purolator filters in my 2025 Kawasaki W230. Looks to fit fine. I do not like the O-Ring included with the wix. It is not a perfect match to the original, it is both larger in diameter and, thicker. The spring under the filter is a challenge. I used some petroleum jelly to hold it in place (the factory does as well. Grease or similar was still under the spring after 100 miles)
I decided to change out my oil at 100 miles just because. It’s a new bike.
