Help with Dewalt tools
key largo,fl
Received these 2 tools as a gift and need a little help with parts/adapters/connectors to attach in order to use these.
Dewalt DCF885
https://www.amazon.com/Dewalt-Dcf885-Lithium-Impact-Driver/dp/B014W2OWZU
(Cordless 1/4" Impact Driver)
Dewalt DCF883 (mine is not the B model but it is the same tool as in link)
https://www.amazon.com/DEWALT-DCF883B-20-Volt-Lithium-8-Inch/dp/B007NVSQEQ
(Cordless Impact Wrench with Hog Ring, 3/8-Inch)
It seems I need to purchase some type of extension(s) or adapters as none of my existing small sockets match these.
Would someone have a suggestion or two as to what I could buy off Amazon or Home Depot to make use of these as I literally have no extensions or sockets or screwset/drills, nothing that mates with these two.
Originally Posted by doitmyself
For the DCF883 impact wrench, you should use impact sockets designed for that purpose (won't shatter). Having said that, I'm sure that many get away with using regular chrome sockets....as long as you are lucky.
Originally Posted by JMJNet
For Screw Driver:
https://www.homedepot.com/p/DEWALT-MAXFIT-Driving-Bit-Set-30-Piece-DWA2SLS30/204786203
For using socket:
https://www.homedepot.com/p/Husky-1...pter-Set-3-Piece-HISKDRAPT3PCN/303256026
This is the search for socket adapter (cut and paste):
https://www.homedepot.com/s/socket%2520adapter?NCNI-5
I have a MAXFIT 3.5 inch #2 Robertson and it's the nicest one I've ever had, I totally recommend them.
An example: https://www.tekton.com/3-8-inch-drive-shallow-6-point-impact-socket-set-47915
Tekton is nice but laser etching instead of roll marked = no bueno.
Would you have a link to ... MAXFIT 3.5 inch #2 Robertson and a roll market set ?
I have several 1/4" DeWalt and Makita (and even a Ryobi) cordless impact drivers...
They are HANDY HANDY HANDY tools to have!
I have several of these sets (I do not use impact sockets with them):
https://www.harborfreight.com/hex-drill-socket-driver-set-3-pc-68513.html
[Linked Image from shop.harborfreight.com]
Great suggestions, thank you all !
For the DCF883 Hog Ring, 3/8-Inch, is there a link anyone would have for a short adapter or something so I could use it with my existing sockets ?
Dewalt DCF885
There are many options. Check the links for pics.
https://www.amazon.com/Neiko-00298A-Impact-Extension-Adapter/dp/B07CMM64FM/ref=sr_1_1?crid=2Q3TEUVPL2WI0&keywords=socket+adapter+3%2F8+female+to+1%2F2+male&qid=1576337292&sprefix=socket+adapter+3%2F8+%2Caps%2C212&sr=8-1
https://www.amazon.com/Titan-TIT12087-6-Piece-Impact-Adapter/dp/B01FKXB5HS/ref=sr_1_2?keywords=Impact+Rated+6+In.+Socket+Adapter+Set%2C+3+Pc.&qid=1576337253&sr=8-2
https://www.harborfreight.com/impact-rated-6-in-socket-adapter-set-3-pc-64768.html
