Originally Posted By: 01_celica_gt
Originally Posted By: Char Baby
To me, the ATF looks typical of most Toyota transmissions that I've dumped! The previous owner probably only changed the ATF once in a while and, only with the 3 qts that drain out. Most Toyota ATF's look sort's Magenta in color when only a D&F is done. And it's gone a bit too long between changes...maybe!
I've seen worst!
It looks very clean on Nick1994's finger in the picture but, Magenta in the drain pan...like most I've seen! Keep in mind that these transmissions hold more than the 3 qts, and the new ATF is mixing with 6-7 qts of old ATF in the transmission!
My wifes Lexus(doens't look as bad) but, has it's ATF D&F'd about every 18 months. And though, hers looks better than Nick's, it still looks Magenta when drained compared to the Cherry Red of the new ATF, regardless of brand. And Toyota T-IV ATF seems to get the discolored the most compared to the aftermarket ATF's, IMHO!
I wonder why? But mine have always drained as if they it was new red fluid. After receiving the initial 3x D&R method when purchased used then followed by 15K OCI
IDK! My is not brown, it's still red-ish but often, off colored(brand dependent). Many that I have done at about 30K-40K miles look more like the Magenta that I described. Any longer, they start to go to brown and then black-ish.
