Had a bad rattle in the engine compartment of my 97 GP with 3.8 and I suspected the waterpump so I put in a new one. Apparently that was the cause of the rattle but now it won't hardly run. I put in new antifreeze and opened the bleeder valve and tried to purge the air. Let it run for about 4 minutes and took off down the road. Started down a hill and it revved up real high and then had no power. I noticed the speedo was not working either. That leads me to believe it is electronic. It started overheating and I headed back to the house. The temp got to about 240. I cut it off and opened the bleeder again. Lots of steam came out and apparently opened the thermostat. The temps went back down to about 200. Went for a short test run but no power. It will hardly go. Also the svc. engine light is now on. Anyone have any suggestions?
[ April 29, 2004, 09:15 PM: Message edited by: wlkjr1951 ]
