Originally Posted by StevieC
If you both read what I wrote above you would see I'm not condoning the mixing of these two. What I said is that if it happened in no great amounts it's nothing to panic about. I then explained why. I provided proof of this and proof of my own situation where it happened. I also explained the TSB by Chrysler.
Again, your own personal anecdote in no way explains away the TSB from Chrysler. 440Magnum did an excellent job going over what was covered in the TSB, if you read what he wrote, you wouldn't be continuing this exchange. Ultimately, that should have been the final word on this subject.
Why you both can't read EXACTLY what I wrote and are twisting it into me condoning people to go ahead and use HOAT in OAT systems is beyond me. And it's not an Ego trip either. But I'm not wrong on this, I have literally done this with 0 issues accidentally myself and neither of you have. So I will continue to dig my heals in on this subject.
demarpaint cited numerous examples from the Jeep forum where negative interactions occurred. Those anecdotes are no less valid than yours. Digging your heels in here certainly comes across as ego-driven. Stating that, absolutely, you aren't wrong simply because nothing blew up enforces that. That's like saying you left a loaded shotgun in your trunk with the safety off and nothing bad happened, ergo, it's safe. You aren't condoning it, buuuuut, if it happens, "no big deal".
Negative interactions between chemicals do not require significant quantities in order to occur. On this topic, since we do not know the exact composition of the products being mixed nobody can say, unequivocally, that mixing them in even small amounts will be safe. The TSB goes as far as indicating that there may in fact be significant issues. Since that's the only formal documentation we have, it should be treated as the authority on this topic.
This isn't the hill to die on.
