I have a 1972 150hp Mercury outboard that I have completely rebuilt. I would like to upgrade the entire ignition system with modern parts, but I'm a little confused as to how it works.
Basically, this motor has a very early version of electronic ignition - no points. I would like to replace the "switchbox" which I believe does the job points would have.
There are three wires coming from the distributor's trigger to the switchbox. Then there is a wire from the coil to the switchbox, and wires for power and tach.
Can somebody help me understand how this works? Is this something I could replace with an electronic ignition upgrade for old cars and a new coil? Are the three wires from the distributor similar to that found in older cars?
