Originally Posted By: Ramblejam
S-SB-0040-09
Nice catch.
Applicability
YEAR(S) MODEL(S) ADDITIONAL INFORMATION
2008 – 2009 xB
Introduction
Some 2008 – 2009 model year Scion xB vehicles may exhibit an ABS MIL “ON” condition with either one or both of the following Diagnostic Trouble Codes (DTCs):
• C0210 – Rear Speed Sensor RH Circuit
• C0215 – Rear Speed Sensor LH Circuit
A newly designed speed sensor connector is available for this condition. Use the following repair procedure to diagnose and repair vehicles exhibiting this condition.
Production Change Information
This TSB applies to vehicles produced BEFORE the Production Change Effective VIN shown below.
MODEL PLANT PRODUCTION CHANGE EFFECTIVE VIN
Scion xB Kanto JTLKE50E#91070695
Parts Information
PREVIOUS PART NUMBER CURRENT PART NUMBER PART NAME QTY
89516-12051 Same Wire, Skid Control, RH 1
89516-12061 Same Wire, Skid Control, LH 1
42450-12090 Same Hub and Bearing Assembly, Rear
Axle LH and RH 2
© 2009 Toyota Motor Sales, USA Page 1 of 3
S-SB-0040-09 July 6, 2009 Page 2 of 3
ABS MIL "ON" DTC C0210 or C0215
Warranty Information
OP CODE DESCRIPTION TIME OFP
BR8015 R & R Rear Speed Sensor Wire (One Side) 0.5
Combo A Opposite Side 0.1
89516-12###
BR8016 R & R Rear Speed Sensor & Sensor
Wire Harness (One Side) 1.0
Combo A Opposite Side 0.5
42450-12090
APPLICABLE WARRANTY
• This repair is covered under the Toyota Comprehensive Warranty. This warranty is in effect for
36 months or 36,000 miles, whichever occurs first, from the vehicle’s in-service date.
• Warranty application is limited to correction of a problem based upon a customer’s specific
complaint.
© 2009 Toyota Motor Sales, USA Page 2 of 3
S-SB-0040-09 July 6, 2009 Page 3 of 3
Repair Procedure
1. Confirm that the ABS warning light is illuminated.
2. Use TIS Techstream to perform a Health Check.
3. If either C0210 or C0215 DTC codes are stored under the ABS System, inspect the rear speed
sensor connectors and sensor pins for rust/corrosion.
4. If rust/corrosion is found in the left rear and/or right rear speed sensor connector, disconnect the
connector and replace the speed sensor wire harness.
If rust/corrosion is also found on the terminals of the rear speed sensors, replace the speed
sensors.
Refer to the Technical Information System (TIS), applicable model year Scion xB Repair Manual for rear speed sensor replacement and installation:
• 2008 Scion xB:
Drivetrain – Axle/Differential – “Axle: Rear Axle Hub: Removal and Installation”
• 2009 Scion xB:
5. After the repair is complete, clear any stored DTCs and test drive the vehicle to confirm the repair.
S-SB-0040-09
Nice catch.
Applicability
2008 – 2009 xB
Introduction
Parts Information
Axle LH and RH 2
89516-12###
42450-12090
APPLICABLE WARRANTY
complaint.
Repair Procedure
sensors.
• 2008 Scion xB:
• 2009 Scion xB:
