I have a 2009 honda fit nearing 127,000 miles. Up until about 115,000 miles it didn't burn any oil, it now burns a little, nothing serious maybe a half quart every 3000 miles but I still check it once a week to be on the safe side. It's been fed high quality gas, pennzoil platinum 5w-20 or pennzoil ultra platinum 5w-20 with OCI around 7500-9000 miles with a mobil 1 110a filter. Current fill is Mobil 1 Extended Performance 5w20 and a mobil 1 110a filter with about 1500 miles on it before the trip.
I usually average 34-36 mpg on freeway and 28-31 in the city so nothing exciting other than a 42mpg trip back in the first year I bought it.
I went on a trip this last week about 700 miles one way so 1400 miles total. Went over a few passes, through a couple rainstorms but nothing too out of the ordinary.
Now the riddle, on the last leg of the trip home I hit a whopping 43 mpg in spite of going over a mountain pass and it only producing a 36mpg run there.
To destination
First leg 36mpg -elevation average 2000 feet
Second 33mpg - elevation average 3800 feet
Third 36mpg - elevation average 4200 feet
Return
First Leg 38mpg
Second Leg 34 mpg
Third Leg 43 mpg
On the return trip I used the same gas stations I used on the way over except at the destination which I used the same brand as the others. Tires were at 35 psi, temperature was roughly the same except some rain on third leg to my destination. The only thing I did differently is before the third leg home I noticed it was a half quart low (full at the beginning of the trip) so I put a half quart of the Schaeffers Moly EP treatment as a means to test if a thicker oil would be better without spending 30 dollars for 5w30 and have to dump it right away if it didn't work. Last year the same thing happened, it was a half to 3/4 of a quart low on a pennzoil ultra 5w-20 fill, topping it off with the same oil I ended up with a 39mpg 60% city/40% freeway run so I don't think it was the schaeffers that did anything.
I have torque pro on my android phone and haven't gone through the logs yet but I'm still stunned at hitting 43mpg on a leg where I expected 35-38mpg.
I'm not complaining, just wondering how this could have happened.
To destination
Return
First Leg 38mpg
Second Leg 34 mpg
Third Leg 43 mpg
