I’m sticking with Valvoline, but can’t decide which would be better for my 25 CRV 1.5 turbo. I do 5k oil changes with a Honda OEM filter. The extended protection has slightly more zinc and phosphorus in it than the restore and protect
Lot of people with 5k OCIs who developed oil burning engines would disagree with you.it does not make a difference for 5k oci's
okay.Lot of people with 5k OCIs who developed oil burning engines would disagree with you.
OP, I wish I could have run Valvoline Restore and Protect from new. I would step up a grade with your Honda engine. I think you'll look back and appreciate this decision years from now.
While under warranty 0w20 is the flavor it’ll get.Lot of people with 5k OCIs who developed oil burning engines would disagree with you.
I'd go with the Valvoline Restore and Protect. 5K or not.While under warranty 0w20 is the flavor it’ll get.
Generally speaking, fuel dilution is not a major concern with most k-series engines, which actually are among the best engines made anywhere. I don’t think it has much to do with the 1.5 T, which in spite of some fuel dilution, is in fact a solid plant. Maybe some of the late 2.4s suffered with low tension piston rings and had some dilution. What is true in both cases, is that most problems are resolved with 4-5k OCIs.Something you should be aware of is I owned a 2015 Honda CRV I purchased brand new. 2015 was the last year of the 2.4L non-turbo engine being put in. After that they started using the same engine you have, the 1.5L turbo engine. I sent in an engine oil sample on one of my 5000-mile oil change intervals. It came back with fuel dilution, red flagged by Polaris labs that took my 0w-20 engine oil down to a 16-weight oil. I thought Honda would engineer the significant fuel dilution problem out of their next CRV release. I was wrong. They made the fuel dilution problem worse on the new engine, they decreased the displacement of the engine, added horsepower and added a turbocharger. On the 2.4 engine, the fuel dilution was a serious issue. Honda spent a few of their hours and my time doing computer program adjustments that their engineers came up with, I went in a few times for this. Ultimately, nothing changed as far as the fuel dilution issue goes on my 2.4. What amazes me is Honda had to know of this problem; however, they released their new 1.5-liter engine that has even worse fuel dilution issues then their 2.4 non-turbo engine had. Honda is not used to their mainstream customers drawing engine oil samples. Most people don't even realize there is such a thing as engine oil or lubricant sampling. My suggestion would be, draw an engine oil sample on your new Honda at 3000 miles, if the test comes back without too much fuel dilution, then test again at your 5000-mile interval. I would use Polaris Labs. The best way to get the kits would be Oil Analyzers, which is Amsoil. Amsoil uses Polaris Labs. Bitog has a Amsoil Bitog sponsor. Check him out, he is @Pablo. He can probably get you set up with some kits. Anyhow that is my advice, and as far as the oil choice goes, buy the highest viscosity @ 100 degrees C 0w-20 engine oil you can find. Of the Valvoline products, they make three products you can use I think, they are all good oils. Pick the thickest one of the three and use it.
I still think he should pull some oil samples, it doesn't cost that much, and there is a lot of info. Maybe do it a couple times, if nothing shows up, don't do it anymore. I do know the Honda 1.5T had worse fuel dilution issues than my 2.4. Maybe they fixed the issue, or like you said, maybe they concluded it doesn't matter.What is true in both cases, is that most problems are resolved with 4-5k OCIs.
I understand. I looked this up, and it doesn't appear the manual makes any mention of 5w30. Usually there's always a caveat. Maybe someone with more knowledge on Honda engines will know if they have different recommendations for different countries like Toyota does. As detailed above, the fuel dilution is an issue, which can be helped with a thicker grade and short OCIs (which you're planning).While under warranty 0w20 is the flavor it’ll get.
Not to say that hasn't happened before but if you have a documented receipt for 0W-20 with your files, scanned or hard copy (that fades), maybe pictures with mileage and dates also, how do they know if you returned the unopened 0W-20 and put in the 5w30 that you bought at the same time on a separate receipt?While under warranty 0w20 is the flavor it’ll get.
5k oci’s don’t guarantee clean pistons(I learned the hard way). Valvoline Restore and Protect will keep those pistons clean. If thats even a problem on these…
Funny seeing these posts immediately adjacent to each other since Glenda developed her problem on Valvoline Extended Protection (primarily).I’d say any Valvoline would work. I haven’t yet run restore and protect but did use Valvoline MaxLife Synthetic 0w20 for the 1st 85k on our 18 rogue. The innards are absolutely pristine. I switched to royal purple HPS and figured I’d get a 1st dirty oil change, it didn’t happen. I have a change of HPL Premium PCMO that I may use next to see if that’ll dirty up. I doubt it.
Nope. Depends on the engine. If I had a known diluter I’d be changing early and often.5k oci’s don’t guarantee clean pistons(I learned the hard way). Valvoline Restore and Protect will keep those pistons clean. If thats even a problem on these…
IMO, like every 3000 miles.If I had a known diluter I’d be changing early and often.
The 2.5, especially before 19 were easy on oil. @ almost 110k I’ll stretch HPS out to 6-7k from late spring through fall and it won’t use a drop. Even the 19-25 version of the 2.5 don’t seem to be hard on oil. I’ve got a tank of ethanol free 90 I’m working through now and she’s purring like a kitten with 4500 on the current oil change.Funny seeing these posts immediately adjacent to each other since Glenda developed her problem on Valvoline Extended Protection (primarily).
Will be interesting to see what you get out of the Rogue. We have a '16 Rogue, and despite dealer changes (and a few dino changes), the engine looks pretty pristine through the fill hole after 70k miles. Still running Valvoline Restore and Protect, but didn't get anything out the first round.
OP - just saw how small your sump is. I'd run Valvoline Restore and Protect or even AMSOIL or HPL. I think the combo of the turbo and small sump makes it highly likely you'll have issues down the road. Here's an example of a Fit without turbo that burned oil even on a boutique. You just bought a new car. The difference in cost to go to AMSOIL or HPL is negligible. My two cents.
