Intake Manifold repair--I have the whole story in a different thread down a smidge. Thoughts on helicoils, they seem to do well when I have used them in the past, but I am still nervous. Below copied from other thread. Thanks.
It is done, and all went smooth until a faulty torque wrench made the day miserable. First rocker arm bolt that we tightened down stripped due to what appeared to be a broken torque wrench, if only we would have used the other (working) wrench istead. Went online and found many folks have used helicoil inserts for this problem, bought the right kit and inserted helicoil. This makes me nervous, even though the helicoil manufacturers clain the helicoil makes stronger threads than the soft metals and metal alloy threads, after all they are selling this stuff, right, what else would they say? After this set-back all goes smoothly with the properly operating torque wrench. The old girl seems to be running fine, actually better with the new plugs, wires, and cleaned injectors. I am hoping the helicoil is an acceptable fix, what say you all? I know aluminum threads are not the strongest to start with, but I am still nervous. I am hoping that the stress on the rocker arm bolt is low, and the pushrods travel is limited more by pressure than the rocker arm?? Other than the stripped thread the fix wasn't all that bad. The PermaDry gasket seemed of much better quality, only a used oil analysis will tell me if I have helped and if the job was well done. At least there is no AF sitting under the valve covers that I can see. Disappointed in GM in regards to a few engineering set-ups. Oh well.
