- Joined
- Sep 15, 2021
- Messages
- 3
Folks, I got myself into a pickle, so I want to fix it right.
I was installing a timing guide onto my wife's car and ended up with a bolt that just kept on spinning and never made it to torque specs. The engine is aluminum and the thread size is M6x1.
My initial solution was to use helicoil, however, the threads are recessed inside about a 1/4 of an inch. This is a problem because the M6 helicoil requires a 1/4 inch drill and the first section of the hole is larger than 1/4 of an inch...that means the threads are either deep or it tapers inside. The other problem is that the tap for the M6 helicoil will cut into the first section of the hole. So, the first section of the hole hole is larger than 1/4 of an inch for the bit, but will be cut by the tap. My fear is that the threads will not be strong enough at the beginning and the instructions want the coils a 1/4 turn below the top of the hole. I don't think it's going to work unless it's okay to thread the coils deeper than instructed.
My other solution is Big Sert by Time Sert. More or less it is an oversized, but more robust insert. Instead of drilling 1/4 of an inch, it will be drilled out .290 and make the first part of the hole suitable for threads...while allowing the use for the original bolt size.
I'm leaning towards the Big Sert, but I welcome your input folks.
Thanks.
M6X1.0 Big-Sert Kit - Thread Repair Install
Bel-Metric sells metric hardware & specialty automotive supplies nationwide. Visit our website to purchase metric fasteners, nuts, bolts, Time-Sert kits & more.
belmetric.com
Thanks.
