Heat Pumps in Nordic Countries
British Columbia, Canada
Here is an interesting article on heat pumps, primarily in Norway. Important points are that Norway trained workers to install them, that heat pumps work reasonably well at low temperatures, and because they act as an energy multiplier there are reduced emissions even if fossil fuel is the energy source for electrical generation. Norway prices fossil fuels so that heat pumps will be the cheapest way to heat your house. Canadians reading this will recognize this as a carbon tax.
We've had a heat pump for at least 5 years and think it's great. Our coldest nights here are occasionally -10C (14F) and it's still working fine. Our electricity is primarily from water power.
https://www.theguardian.com/environ...s-cold-heating?utm_source=pocket-newtab-en-us
We had heat pump in the previous place, but it was the dumb heat pump which could only warm up the whole unit. I was thinking is it really more efficient than a simple electric warmer that only warms up the bedroom at night? Nah :D
This year we completed installation of low ambient temperature MItsubishi heat pumps. We left our oil fired hot water heating system in place. We are on a time of day rate in Vermont, which largely reflects the fact that during the off peak periods (16 hours every weekday and 24 hours on weekends), our power is hydro power sourced from Quebec.
The heat pumps still work below zero, but work harder. We usually switch over to the oil heat when the temperature falls that low.
They try to sell whatever they can with promises that you won't find out out if true till it's too late.
2 things are possible: they may have improved the technology and they could be an interim tool till the real furnace is needed.
1 thing is certain: NO WAY will they really be able to keep you warm in the Nordic temperatures unless you wear down underwear.
:eek: ;)
Northern Ontario here.
-10C is an average high here for the coldest months.
Heat pump is not on my priority list, at all.
For another view on the topic, there's this.
It’s all about the sizing relative to the house. The modern heat pumps have no problem down to minus 18 C here before the electric coil backup kicks in.
Yup, and efficiency-wise, I suspect the hybrid setup, where you use gas for the super low temps (which is how mine is setup) is better, where you are ultimately going to be using resistive and it minimizes the peak load on the grid, which is why Quebec imports from Ontario in the winter.
When we replaced our AC condenser and evaporator my wife told me in no uncertain terms that it would not be a HEAT PUMP. She has had experience in places with them and said she wanted to feel heat coming out of our vents. So we have a great AC unit and a propane furnace.
Air heat pumps are great for winter heating and are very popular in the Nordic countries, for a good reason.
Here’s for example Mitsubishi Electric EF25. It has COP of 2 even at -30C (-22F). (meaning that with 1kWh of electricity you get 2kWh of heat).
From the figures:
-Blue = input power (electricity)
-Purple = output power (heat)
-Red = COP = heating efficiency calculated from the two previous values
https://scanoffice.fi/vttn-testiraportit-ilmalampopumppuvertailu/
He's talking about air to water heat pumps used to replace boilers. Doesn't really apply to those of us in the US or Canada. We use forced air here and forced air works a lot better when it comes to heat pumps.
Air to air heat pumps have come a long way and most people are not up to date on them. When you mention heat pumps to most people they think of the ones from 30 to 40 years ago that were useless below 30 degrees. Modern heat pumps using inverter driven variable speed compressors are capable of heating well below 0 degrees F.
Heat pumps and EV are popular in Norway for a primary reason - near free electricity in the northern areas. So much water, so much hydro, it’s a no brainer regardless of the price of gasoline and natural gas.
But their sentiment is changing as that electricity can be exported to the rest of Europe… which will drive their prices towards market prices.
This was a sore point with every Norwegian person I met last summer when travelling there extensively.
