I have a new 2 ton heat pump and the air temp. coming out of the register is 91 degrees. It's 37 out and 68 in the house. This heat pump has only one zone. Is that high enough? I just had the Freon checked and it was fine.
I have another 12 year old heat pump that is a five ton and has several zones with a zone panel and it has a large bypass to redirect the air back over the heat pump coil when only using one zone.
When the 5 ton is operating with only one zone open the register temperature is 122 degrees coming out of that zone.
Is this because the five tons is being concentrated in one small zone and the air is being heated by the coil and then some is bypassed back to the coil to heat it up higher?
Thanks a ton!
Thanks a ton!
