I have a 1.5 engine mitsubishi lancer 1998 changed the short block which is the motor unit from 1.3 to 1.5 now after 1000km trial easy driving the engine didn't consume any oil using 20w50 full mineral SJ rated oil " which should be changed every 3000km " after that i changed the oil and ran it for 2000k " the mechanics here use this process to clean the engine from inside " but this time around i was driving it fast most of the time between 120km to 140km while the top is speed 180, when i was changing the oil it lost about 1 liter of oil but no smoke whatsoever, did it lose oil due to high speed driving? Even at such thick viscosity! Or is it the beginning of worn rings? The mechanic said it might consume abit till seals inside get its pliability back as it has been sitting at the dealer shelf for sometime so it might dry out which is normal
