My dentist gives me two tiny tubes of headlight polish a year. Makes the garage smell minty fresh.
I know what you’re referring to. Let’s face it, how many times have we done this job? Me, four. So the sample size is not large enough to know everything.I've tried kits in the past and got so-so results. One headlight almost looks like the inside of the lens is oxidized also. I now use Mr. Clean Magic Eraser pads and get the same results as the $35.00 kits. One pad costs about $1.00. I've just made it part of my oil change routine; when the oil is draining I do the headlights.
All fine, but at what cost? If $16 buys 3 years, would that be more reasonable, than for one of my cars:There is not a real solution other than making sure your housings are maintained.
When they hazer over, you just replace because the chemicals are just buying some time. The issue is within the polymers or plastic layers, its sort of like trying to put an additive in an engine with bad rings... The damage is done and can only undone one way.
The products that have a "sealer" as they say, is really just a spray on clear coat. That clear coat will create more issues down the road and that time period will get shorter and shorter until its lasts just a few weeks. One of the reasons it makes the issue worse is due to the first steps scarring the heck out of the plastic lens, sure it gives you the perception of removing and leveling the deformed plastic (haze) but its just because its stripping even more away (including any needed OE coating) and leaving even more uneven surfaces, through scratches. Then your "clear coat" fills in the scratches for a period of time, in that its not buffing or polishing away the unevenness... It's filling.
Remember guys, there is no chemical solution for a mechanical problem.
This then gets me to the original point of all of this, for me its about safety... Therefore I just replace instead of decreasing the safety over time and creating more work.
I always thought the haze at the top was due to increased heat from the under the hood coming down onto the lights.
I also see that someone mentioned one light hazing faster than the other, you may be finding that one of your lights was replaced due to an accident and they used an aftermarket part that doe snot have the same lens treatment as the OE.
If you are working on an older vehicle with square plastic housing, you might be able to E-CODE housings for it, which will be glass. I used to do this to my XJ's and it was an amazing upgrade.
Yeah any of those krylon or whatever type clear sprays won’t hold up. If you don’t have spray equipment you can get spraymax 2k clear in aerosol. You pop a tab on the bottom to release the activator before spraying it.I went up to 3000 grit as the final step on mine. Completely worth it, but not absolutely necessary. It’s mostly just because I had it up to that grit. 1500 as a final grit would suffice in most cases. I have never had any luck with clear spray - then again, I didn’t use 2K Clear or anything specific to plastic, so probably that was why.
I use toothpaste works fineI tried the Turtle Wax Headlight Lens Restorer Kit (about $21) and I must say TW had their chemist's working overtime.
It is a multistep process with a 'clarifier' that uses aluminum oxide as the very mild abrasive as the first step.
Then a lubricant is used with two pads and four sides to remove the oxidation with each pad having two sides for subsequent steps. Then there is a sealer system for the last step.
My lenses were very oxidized and I must say it removed 75-80% of the oxidation and clarified the headlamps considerably. Plan on about 2 hours minimum of intense 'elbow'' grease.
The driver's side headlamp had the worst oxidation, but the interesting thing was that most oxidation on both lenses were located at the upper 1/4 quadrant of the lens.
I do the same thing on my beater I just follow up with a coat of wax Meg's ultimate liquid waxI've tried kits in the past and got so-so results. One headlight almost looks like the inside of the lens is oxidized also. I now use Mr. Clean Magic Eraser pads and get the same results as the $35.00 kits. One pad costs about $1.00. I've just made it part of my oil change routine; when the oil is draining I do the headlights.
I have been using the similar Autosol metal polish. Works great on my Tundra, but I have to redo it every 4 months or so. I have been using this for about 5 years now.I just tried some FLITZ polish this past weekend and it is the CATS A DOUBLE S! I have tried all the various methods and FLITZ has them all beat. No kidding. Drop about 5 bucks for a tube and try it. Just use a soft cotton shirt and rub it on and into the lens gently. I'm gonna use the Sylvania kit's protective layer but the FLITZ is just WOW!
