My mom's 2007 Impala had the head gaskets replaced under warranty about 3,000 miles ago. Everything has seemed fine since. I had to top off the coolant just a tiny bit - it was using about 10 ounces of coolant every couple thousand miles before the gaskets were replaced.
Today I decided to drain and fill the radiator and when I ran the engine with the radiator cap off, there were tons of tiny bubbles. I mean it was like sticking a straw in water and blowing as hard as you can kind of bubbling. The level dropped and I kept topping the system off and the bubbling slowed down, so some of it was trapped air, and buy that time it was about to overflow so I stuck the cap on.
There's no other signs of a head gasket leak. No overheating, not steam out the exhaust. I'd think a leak that bad from the combustion into the cooling system would have all the other signs of a bad gasket failure.
What are your guy's thoughts? Anyone had a head gasket leak the made bubbles in the radiator with no other symoptoms? Maybe it was all trapped air.
