I fully understand the indisputable fact that rotella doesn't do good in the lab but in the real world I'm not seeing rotella be an issue. mechanical injection engines should be having issues with high foam rotella but they seemingly don't. Looking up heui injector issues with rotella on here and elsewhere yields nothing. There also doesn't seem to be a sludge issue with rotella either. They don't seem to have wear issues either. Still I won't be buying it for the time being but I'm not sure it's that big of an issue.
I see it all the time in the racing world. It's just that most of the issues are blamed on something else or are taken as normal with abusive racing use. If you're convinced, beyond any shadow of a doubt, that the oil you're using is god's elixir, you'll never consider it to be the cause of any issues. "Well, I got good oil in it so that can't be the problem." What's sadder is they only think it's good oil because Joe Schmoe on Facebook, who thinks a 5W-50 is less viscous than a 10w30, told them so. "T4 has been great. Oil pressure is great, no issues at all." "What about the fact that you're on your 3rd set of rod and main bearings in 2 years?" "Oh, that's just the cost of racing. Engine's run hard, things break, it happens." *looks over at my engine using a 0W-12 oil with the same bearings for 6 years now* ... "Ok then." Many of these people also think "oil is oil" and thus don't even consider that a better oil is even a thing.
