ringmaster
Point taken! What about the suggestion of damage from the ZDDP?quote:
Originally posted by JohnBrowning:
P.S. What is next seperateing two ply toilet paper into one ply?
Sorry John, your wrong, I've done it. Granted, it was a great difference, but it was statistically significant.quote:
Their is no way that the under reaql world conditions anyone would be able to accurately measure their MPG close enough to reflect the difference. We are talking about compareing Esso XD-3 to a thin M1 0W30 correct!
Who needs English classes when you have a spell checker? What I need is a memory improvement class so that I remember to use the spell checker. A typing class probably wouldn't hurt too.quote:
Originally posted by TooSlick:
English classes are also worthwhile...![]()
Quote:
I would like to know number one how large your data set was? I would like to know what calibrated instruments were used to accurately measure fuel flow in relation to milage and power output? What is the resoulution of the instruments used? How did you elimanate all other variables luike atmospheric variations,variations in load, drag variations etc? I realise that what you propose is possable but not likely. Few people have the equipment to do such work properly. The lack of controled environment alone add's a lot of variables that are outside of the testers control when test's are not done on a test circuit or dyno. You more then anyone should understand how large your data set would need to be to be significant to anyone but yourself.I have seen some of your threads and math is definately one of your strengths!!!!
Quote:
It is a new rig, 2005 model! Is the XD-3 likely to damage the cat and 02 sensors?quote:
Originally posted by Steelhead:
if you have new rig, worry about cat. and O2 sensor damage from high zddp Phosphorus 1300 Zinc 1350 in 2005 VOA Esso XD-3...a dying cat or O2 sensor will cause far more lowering of fuel mileage
Quote:
Keeping wear to a minimum,useing non-volitile oils and keeping your seals happy will do more to prevent cat death then reduceing additives in oils.
Quote:
To listen to some tell it you would think that converters are just plugging up left and right. It is simply not the case.
