^^This^^Defending my home against someone that's already inside isn't the place for a less lethal round IMO. Especially when geeked out people have been known to shake off hits from less lethal and keep coming. Maybe as a first round, but after that, it is time to move on to making them leak.
How far away do you plan on shoot them for the pattern to be that large?As previously mentioned…9 shot. A light load will ensure that there are no penetrations in walls making others collateral damage. If the need arises to defend yourself, family, and property the 9 shot will scatter more making your shot very effective. An intruder with 9 shot in their eyes, face, guts, groin, and/or ass and back will be incapacitated.
EDIT: Try all the loads mentioned against a sheet of sacrificial plywood. Fire from a distance such as the width of your bedroom. See which load has the most effective spread along with the least penetration. My guess is you will choose the light load 9 shot especially with family in the home and living with shared walls.
I like this suggestion. I have a mag of Federal high brass 00 buck for mine that would be used if required, but I'm in a single dwelling with double brick walls, the reduced load sounds like a good compromise with shared walls.00 buck in LE reduced load. Quite effective without the punishing recoil. The LE slug is not near as brutal on the shoulder either.
Select your poison and pattern it on a paper target so you know the impact size at the range you will be shooting.
MHO
Smoky
Excellent point.30 years ago I killed an average sized whitetail doe and while skinning/butchering her I discovered a mass of birdshot pellets in her neck barely beneath the skin and not even down to the vertebrae. The pellet density was pretty high, indicating she had been shot from fairly close range before they had a chance to spread. There was no obvious wound and she appeared to have fully recovered with no noticeable impairment.
I learned all I needed to know about small shot as a defensive option from that deer. Birdshot lacks the sectional density needed to reliably penetrate into vital organs, especially if your home invader has a layer of fat or is wearing a heavy coat. You need big, dense pellets in order to maintain momentum. Round balls are very poor penetrators compared to pointy bullets. A 00 buck pellet and an 8mm rifle bullet are both 32 caliber but the pellet weighs around 80 grains and the bullet weighs 200+.
Legally, shooting someone with a shotgun is considered lethal force. It doesn't matter what size shot is in it. You shot them. With a shotgun. Could tbey have possibly died? I bet the jury says "yes".Excellent point.
Also, a few other points:
- Using lethal force, which a gun of course is, has requirements related to eliminating the threat, which you perceive to be life-threatening. This is why you cannot shoot to maim. I would question whether dusting somebody with birdshot knowing that the odds of it being non-fatal are high would also fall under that same category?
- If the person is on some sort of substance, what might hurt like hell and potentially incapacitate, but not kill, your typical sober person could be of no consequence to them. In this case, having an effective round chambered that is going to neutralize the threat posed by this individual is paramount.
In Canada, you absolutely need to be in a life-threatening situation to use lethal force, and you will still be charged, but if it is justified, the charges will be dropped. I have a mag of high brass 00 buck that will absolutely do the job, if, God forbid, the requirement to do so ever presents itself and I think that's how it has to be considered, IMHO.
This. I prefer le13300. For slugs, its LE127RS.00 buck in LE reduced load. Quite effective without the punishing recoil. The LE slug is not near as brutal on the shoulder either.
MHO
Smoky
As a cop told me, things go much, MUCH smoother when there's only your side of the story to tell. Peppering them with birdshot, maiming them, in addition to what I already said, well, increasing the odds of them surviving is not going to work in your favour.Legally, shooting someone with a shotgun is considered lethal force. It doesn't matter what size shot is in it. You shot them. With a shotgun. Could tbey have possibly died? I bet the jury says "yes".
