turtlevette, firstly bash it.
secondly, you have now proved that you've never worked in a thermal power station...our big drives (2500hp and up to 12,000hp (I'm using hp, because you definitely aren't a power station guy)) have circulating oil systems (with coolers), a bearing located oil reservoir, and oil rings to supply the unloaded side of the bearing.
Older designs used grease in the couple thousand hp range, but the 9 through 12 thousand were all oil lubricated even in the 60s.
"Pelton" turbines and a couple of quarts of straight 20 is like a 100 year old town supply off a local dam, not a "power station"....even a cooling water pump on a thermal has 20L of oil and a cooler.
Originally Posted By: turtlevette
An engine will make much more waste heat at a higher rpm. It doesn't matter if the same power is delivered to the road. That's shameful you don't get that. You want to argue it out? I guarantee I'll win that one.
I showed you with the bearing model where the waste heat is generated, hydrodynamic friction, increasing exponentially with RPM is a large part of it...
But if you want to explain how much more "raging inferno" there is in your intuitive world have at it.
You've again ignored every bit of science I can send your way.
You WILL win, because you have much more experience in turtletopia, where your twisted version of physics works.
