Havoline Multi-Vehicle + BG additive, interval?
CA
My gf has a 2007 Accord, I4, with about 103k miles.
When I met her, the car had about 96k on it and the ATF looked like it had not been serviced in a very, very long time.
So, I did three drain-and-refills using Havoline's full-synthetic multi-vehicle fluid. The car shifted a bit smoother afterwards but the shifts were on the harsh side.
Note: Havoline's site does list Honda ATF-Z1 and DW-1 compatibility.
Since I still had 3 quarts of Havoline fluid left, I did another drain and refill using the same fluid and also added a small bottle of BG's ATC Plus additive. I found the product on my parts shelf and figured that I would give it a try. After all, it is the girlfriend's car, right?
The transmission shifted better after adding the additive, but it still does not shift quite as smoothly as I would prefer. The shift quality does not bother her, but I should probably service the fluid with Honda ATF-DW1 fluid or something different...eventually.
My question to you folks is -- how long should I run this "mix" for?
Originally Posted By: Mr Nice
Stick with Honda ATF.
This, I've always been under the impression that Honda transmissions where very finicky with fluids.
We use Havoline/Chevron lubes at work and have for many years Honda-Z1 is the same as Havoline Multi-Vehicle ATF and Honda DW-1 is Dexron 6 as far as my Chevron Havoline Guide. I don't think that using Havoline causes problems as we have used over thousand cases and had no trouble at all in any car.
Originally Posted By: bvance554
You just measured your relationship in miles. 7k on her so far.
Where is that Dave Barry essay on this?
Update -
Just got in from flushing out the "concoction" with about 9 quarts Genuine Honda ATF DW-1. Also replaced the in-line filter.
For future reference, on the Gen7 Accord four-cylinder, the supply line to the ATF cooler is the line closest to the L/F corner of the vehicle.
I drained about 4 quarts -- added 4 quarts of new fluid -- started the car and allowed 4 quarts to drain out -- added another 3 quarts -- started the car and allowed 2 quarts to drain out (fluid was bright-red by this point) -- reconnected line and r/r the in-line filter -- topped off with another 1.75 quarts (after waiting for the radiator fan to come on twice).
Impressions? Overall, it shifts a bit quicker and more noticeably, but the 1-2 shift is a lot smoother than before. Oh, and I'm about $80 poorer...
I still don't get what smooth means in reference to an automatic transmission. Smooth in that context means clutch slip and heat,no?
