.....using a switcheable electric pump with two fittings/bungs welded to the oil pan. It would be completely separate. oil would be drawn from the oil pan and returned to the oilpan after filtering and maybe even cooling it. One could use a dry sump oil pump to rig such a system. The intake could actually be the oil drain plug and the return could be installed in a different position. A cooler could be hooked into this system too. All without straining or restricting the main oiling system for the engine.
