My 14 Mustang GT just hit 25,000 and I want to change the transmission fluid early to get out the break in material. I bought another factory tranny pan and had a drain plug bung welded in so I can do drop and fills later on.
Does anyone know if you remove the small dipstick down on the transmission while the car is off, if the fluid will spill out? I plan on measuring how much fluid is removed when I drop the pan and put that much back in with a little extra for what the filter might still have in it.
I know there is a video on youtube that shows you how to change it on this trans but I don't have a lift, just ramps, so I don't have a good way to get the car level.
Or, should I just take it to the dealer for them to do it and hope they will install my transmission pan. I know this transmission has a internal thermostat so getting accurate levels are more difficult without it being on a machine. Thanks.
Wayne
Wayne
