I haven't changed the oil on all that many cars over the years. The hardest spin-on filter to reach & install/remove was on a Chevy Citation 2.5 L 4 cyl. Transverse mounted engine, filter mounted high on the rear passenger side of the engine block. Those were otherwise pretty good little engines, IMO, but the oil filter location was *bad*.
I only change the oil on that car 3 times- and once, I'm ashamed to admit to not changing the oil filter.
On the 94 Mercury Grand Marquis 4.6 L V-8 I looked at the oil filter location, tried to imagine getting it out of there without making one mell of a hess on the driveway/carport floor(at the time I didn't even have ramps that car could "climb"!), & decided it was best to let the local service station change the oil on that car. Discretion the better part of valor, etc.
Easiest car to change oil on, in my experience, is the one I have now, the 97 Neon- but only *after* I found Rhino Ramps.
On 95-99 Neons the oil filter hangs vertically, only inches away from the drain plug. Just don't use a filter that's too long, it'll peek out from under the oil pan & cause big problems when you knock a hole in it!
