Hard to Find Fitting?
Australia
I am seeking heelp to find a source for hard to get fittings! I am sorry I'm not technical enough to know how to describe properly what I'm after, or what it's correctly called!
I wish to run two bypass filters on a 1992 Toyota landcruiser 4.2 litre turbo diesel engine, one a sub micron cotton oilgaurd type cannister and the second a centrifuge type filter!
I do not want to run these two bypass filters from the engines existing mechanical oil pump, the pressures low enough already and these engines are renowned for grabbing ans spinning the big end bearings shells inside the bige end caps!
I figure if I tap the oil system from the block fitting for the oil pressure gauge and bypass that oil thru two separate filters mechanisms - the resultant drop in oil pressure could be enough that it triggers the crank to spin a bigend bearing shell.
Instead I want to tap into the sump and use an external electric oil pump to recirculate and clean the sump oil thru two bypass style filters, totally independant of the engines main oil pump!
The problem I will have is in being able to tap the sump pan to get at the oil, and again - being able to tap the sump pan - to return the cleaned scrubbed oil!
I want to tap the sump pan twice - without pulling the engine to remove the sump pan, clean it and weld tubes into place to achieve this.
I have been told - there is some kind of fitting you can buy - where at oil change time - you drain the sump, use a small grease covered drillbit to drill a pilot hole where you want to tap the sump pan - then insert a self tapping, self sealing type connection fitting - that will then allow you to fit oil pressure hose with a swaged end fitting onto the fitting!
I don't know the proper name of the fitting, or where you get them, but am hoping someone before me has come across such a fitting somewhere and can point me to a link for such!
If anyone knows if any links to external 12V operated oil pressure pumps then a link also would be much appreciated!
I hope I've given enough info / description to make it clear what I'm looking for!
Please ask questions if I havent!
Many thanks in advance!
Cheers!
Okay, I'll give you what you ask for.
Amsoil BP-40 and BP-41 (gasket). I think that it retails for about $3.xx for both ($6.xx in your case).
If you're affiliated with an Amsoil dealer currently, contact him/her. If not, I'll be happy to help you get it.
I don't think any of the preoilers are designed for continuous use.
I think this is
Just google Mocal. Not cheap ..but neither is a centrifuge.
You can return to the valve cover ..and if you don't want to punch a hole in the pan, there are setups that draw from the drain plug hole via a banjo bolt.
Gary - I appreciate that, and no I'm not associated with any Amsol agent so will definitely source my eqip from you direct (I'm located downunder so not sure we have Amsol agents here?)
I have 2 TD engined vehicles, a Yr Model 2004 F250 7.3PSD 4x4 & my 1992 YM 4.2 TD Toyota Landcruiser 4x4, both od which run on disel/LPGas a and have an idea in mind....for oil quality management/replacement!
Most of you likely know how hard the PSD's generally are on oil shearing, and you also know - that they have a HPOP that uses dirty oil from the sump as a high pressure hydraulic oil to dirve the HEUI injectors.
Anyones had much to do with hydraulic machinery will know how important it is to keep hydraulic fluids as clean as possible!
Replacing at some point in the future - the 8 HEUI injectors @ US $300 A peice, is more than we used to pay for a whole engine some 15 years back! If we mess with synthetics / bypass filtration & UOA for extended oil changes and as a result we put that dirty sump oil thru hydraulic injectors and wear them out prematurely & coke / gum them up with suspended soot & varnishes etc as a result, well any oil savings gained evaporate pretty quickly for new/replacement injectors!
I would like to develop for my 7.3F250 & 4.2Cruiser a total oil management system, much like some long haul trucks are using!
My idea is to install a external 12V oil pump, to be used independant of the engines main (and HPOP) pumps, to recirculate the sump oil thru both sub micron oil guard type cotton wound element filter and also a centrifuge filter to clean it independant of the engines oil system...
While it is doing that I want to install a 6 US Gallon new Oil reservoir, into the vehicle, complete with a sender unit and low oil alarm / light on the dash somewhere, that tells you when it needs topping up! (every 12 - 15,000 miles).
I aim to have the oil scrubbing system - bleed off a small measured amount of cleaned oil (say 1/3 pint) every couple engine operating hours, and pump it back via a line to the diesel tank - so it can blend with the diesel and be burned as fuel.
At the same time - I aim to have the reservoir of new oil replace that used oil with the same amount of new oil.
My aim is the have the entire sump quantity (16litres) of oil continuosly scrubbed clean - and recycled as fuel, and completely replaced replaced with new oil - every oil change interval of 3000 miles or 6000 if your on synthetics and getting extended oil change intervals!
I want the sump to stay full all the time - the oil to always be clean - the used oil disposed of as fuel to save a $ on diesel costs, and no need for oil changes ever again!
All you do at oil change time - is top up your reservoir with a 6 gallon tin of new oil, change you OEM Filter, Your Bypass Filter element, disassemble your centrifuge filter and clean/reassemble, and your good to go another 3000 or 6000 miles!
I can't see any good reason why this idea can't be achieved?
OK - It might take a small computer to control solenoids or something to replace the oil and pump the used oil to the diesel fuel tank via the return line etc, but it shoudn't be that hard!
I figure if I can downsize the type of system long haul trucks use and make it suit my F truck & Landcruiser - then maybe I can market it online as a DIY kit form!
It makes sense to me!
Has it already been done?...or are there any good reasons not to do it, that I've overlooked?
I can't see such a miniscule % of used sump oil if it's passed thru micron & Centrifuge filters and across neodymium magnets etc - that it should contain enough suspended soot particles or wear metals to cause any issues being burned as fuel thru the injectors in a 5% blend with diesel?.
If it was old dirty used sump oil - then yes different story, but if it's continuosly scrubbed clean & replaced with new oil - then surely it would be Ok to burn at blend concentration of less than 5% with diesel?
I am thinking the whole thing could be user "programmable" like your DP Tuner chip is - Programmable so that you the owner, can infinitely vary and set the hours useage perameters for total oil change - depending on your driving style & useage and oil type, maybe even have 4 or more "pre set" programed settings - Dino "town use", "severe duty cycle", "towing", "highway" and the same settings again for Synthetics, etc...where either more or less oil is replaced per engine hour use!
Thoughts +ve or -ve please anyone?
Cheers
maybe I'm confused...
you say you want to clean the oil so as not to harm the hydraulic injectors and to get EOCI. But then you mention having a sump to replenish oil as you'll be sending the cleaned oil back to the fuel tank to burn.
Sounds like an engineer with too much time on his hands. A solution in search of a problem. :shrug:
Well, I imagine that no matter how good he cleans his oil, it will eventually need exchanging. I don't know how long soot control can be maintained, even with a centrifuge. He'll need to add some oil just to keep the TBN up ..so the self recycling technique could prove very handy.
Maybe I wasn't clear.
The oil in the sump will be continuosly recycled and scrubbed as clean as the two filtration systems will get it and returned to the sump.!
A small %age of cleaned scrubbed sump oil - once every hour - will instead of being returned to the sump - pumped back to the fuel tank, via the diesel return line to be blended with the tank full of fuel to be burn't!
The amount removed from the sump is replaced with new oil from the on board vehicle reservoir!
The amount that are removed hourly and the amount replaced need to be the same.
The amount removed is ca;lculated such that the entire sump of used oil is replenished with new oil over the period it would normally take for your oil to need changing!
Thus if you changed 16 litres of oil in the sump, over a distance of 3000 miles at 60 miles an hour or 50 hours travel...you would be sending 32 millilitres of used oil off to be used as fuel each hour and replacing it with 32 millilitres of new oil from the on board reservoir and this happens for every hour of engine use!.
At the end of the 50 hours, when ytou've done 3000 miles - your due for an oil change - excpet - your oil management system has already done just that for you - you ow have 16 litres of new oil in the sump from the on board reservoir, you have recyled 16 litres of used sump oil thru your fiuel tank and burned it as fuel (no waste oil to get rid of) and you've saved:-
4.23 US Gallons of diesel (16 litres) you haven't had to purchase because you burnt waste oil in it's place @ $2.50 a gallon or ~US$10.
You've saved the cost of an oil change at your friendly ford stealership - because your engine oil management system has changed the oil for you!
All you need do is change & clean filters at the recommended interval and remember to top up the reservoir with new oil every second oil change interval. (The reservoir should be big enough to go two complete oil change intervals) before needing refilling!
Now - if you use conventional and change every 3000 miles then your replacing 4 and a bit gallons a time so a 10 gallon reservoir would do!
If you use synthetic oil and go 6000 miles between changes, then your going twice as far or twice as many hours so you'd only program your system to replace 16 milliliteers of oil an hour or get it to send the same 32 millilitres to the fuel tak every 2nd hour and replace the same 32 millilitres with new oil each second hour, but because of that - you'd only need to carry half the volume reservoir...5 Gallons, to keep up with your systems needs!
Does that make any more sense now?
http://www.enginecare.com.au/parkerWebb_doc.htm
Heres a link to a commercially available system for trucks that is basically similar!
Cheers!
I understand what you're doing-- but I don't understand why. I wasn't aware it was that difficult to change oil. : shrug :
definitely sounds interesting, but I'm wondering if you're not just adding additional points of failure along the way.
Not knocking it, just discussing it with you.
I undertand indeed, nothing wrong in discussing the idea - thats what I posted it up for in the first place!
Why would trucks use it!
Could it be because it extends engine life - reduced downtime and saves the cost of paying a mechanic to service you oil system?
Could it be because - the extra filtration helps reduce wear in the expensive to replace hydraulic injector system?
Could it be that you could also add an auxilliary engine oil cooler to the system to help lower engine temps.
Theres a lot of potential benefits I think, to not running on ever increasingly dirty oil right up to change time - instead running on clean scrubbed and new oil.
What do you do with your waste oil now - does someone pay you $10US for it, towards your fuel bill?
I can see a lot of positives!
While we talk about the negatives - what of it stopped working?
Well if it stopped working - you'd have what the manufactirer put out originally - a engine running on a sump full (16litres) of progressively dirtier & dirtier oil, until oil change time some 3000 km's down the track.!
Yes theres more systems to go wrong but if it's separate to the main engine oil pump, does it really matter if it does cease working for a while, until you get it fixed?
Just thinking this thru out loud!
Cheers!
I completely agree about the bypass filtration-- this is why I am adding it to my vehicles.
I just don't understand the need to automate the move of the used oil to the tank, or the refill of the oil into the engine.
For that matter, if you're running BPF, I don't see any need to do anything other than leave the darn oil where it is in the first place. You're cleaning the oil VERY well-- let it stay there. Oil doesn't wear out, it just gets full of contaminants, which you are removing. The additive package goes bad, but when you service your filtration, you'll be topping-up what you removed. How hard is adding a quart of oil?
If you must go with the autoflush/fill setup, why not just run it through a BPF and then into the tank, and be done with it? No need to filter the oil if you're just going to keep throwing it away, IMHO. Of course your stance will be that the engine oil hasn't been "Scrubbed" and so you're having unneccessary wear, and I agree. So scrub the oil with BPF, and run EOCI based on UOA. Change the oil- maybe- every year or so, based on UOA lab's advise. Take the oil you drain, filter it outside the truck, then put it in the tank.
I understand your goals, I just think you are building a space shuttle when a bicycle will do, mate
something to think about- depending on the failure mode, it could be possible for your system to drain the sump into the fueltank, leaving you without vital lube for the engine.
Or, conversely, it could overfill the sump, which can also cause expensive problems.
Just something to think about.
He he he,
My wife points out to me - that being a self taught typiste that I am, I have a very bad habit of not usisng full stops on each sentence and instead using excalamation marks on every sentence...she's good like that - she finds and makes a habit of pointing out ALL my faults!
Reading my posts - it's apparent she is entirely correct. Deliberately uses full stop.;)
Anyway she says this is why I get into so many agruments on the internet, because I make each sentence into a emphatic statement, by over use of the excalmation.
Well I'll be dammned - I do get into a lot of arguments on the internet and I don't go looking for them, I'm just trying to bounce idea's of like minded people.....yet the arguments just seem to follow me round & I can't shake them, just like the cloud of flys that follow "Pigpen" everywhere he goes in the ol Charlie Brown comic strip.
So now I know whats causing it...
Having said all that - yes I currently have Bypass filtration on one of my engines (the 7.3 psd) in form of an oilgaurd arrangement.
I also do used oil analysis - using the oilgaurd labs in the US.
This is where I'm different to most I guess, - I don't do all this - in order to get longer oil change intervals.
I still change my oil every 3000 miles (5000km's)
Both of these engines have lpg conversions - where they run diesel and LPG simultaneously. One of the claims of the manufacturer, is that becuase the LPG creates a much more complete burn of fuel (up from 87% to 99% efficiency) that there is MUCH less soot in the oil.
I have only just added the bypass filtration to the 7.3 and as yet haven't added it to the 4.2 TD cruiser.
I've sent the first set of Used oil away for both vehicles taken prior to any of the lpg or bypass filter mods and recieved back analysis that say both engines are in fine condition, nothing abnormal.
Then I've changed oil, and run another 5000km's (3000 miles) in both vehicles and collected more samples, both waiting to be sent off, I did the samples hours before we were leaving on a 6 week holiday, where both vehicles did another 5000km's (3000 miles), on the new oil in just a matter of weeks, and I'm due to sample these now and send them off - along with the previous set, and I should have something them to compare against my original set of results, and I should be able to tell both how well the oilguard works in the 7.3 and how much extra or less soot their is in the cruiser (and hence how valid the claims of the LPG conversions crowd are).
One thing tho - is that both the son & I who drive these vehicles - check the dipsticks, regularly for oil level, and we both feel - that we are seeing a marked increase in soot levels much earlier than usual..since adding the LPG conversions.
The cruiser particularly has always been a rare engine that seems to do 5000km's and when you change the oil - it is barely dark at all - in fact you put tissue into the oil, it has a slight grey tinge is all...
But our initial observations of the dipsticks now seems to indicate the oil getting blacker quicker/earlier in the oil change period. (Which is contrary to the LPG crowds claims).
We could be wrong it could be that with the excitement of all the modifications, we are just paying more attention to the dipstick and oil condition than before, and to be truthful I don't want to make statements on the internet saying soot levels are up if they arent and we should know for sure just as soon as I send these last 2 sets of samples away and get back some results to confirm with a verifyable test result from oilguard.
So I have been worried - about what effects extra soot in the oil from LPG MIGHT do to the 7.3, and whether the bypass filter can trap all of that and remove it or not.
The rapid darkeninng of the oil on my dipstick suggests not, but again I don't want to prejudice anyone before the results are in!
I found some interesting information at the "kleenoil" website, that managed to convince me that maybe just bypss filtration on it's own isn't the only thing we can do to protect our engines, excerpts of which I'll repeat here FYI.
Quote:
The cleanliness of your hydraulic fluid is critical to the trouble free and cost effective operation of your system. Hydraulic components are very expensive and need special consideration when selecting and filtering this fluid.
ISO 4406 (International Standards Organization) code is a standard that is recognized in the industry. Certain recommended fluid cleanliness quantities are necessary to realize the best performance and cost saving operation of your hydraulic system.
The ISO 4406 cleanliness level standard is used to reference the number of particles greater than 5 and greater than 15 microns in a known volume. For our usage, this volume will be 1 ml. The number of 5+ micron particles is used as a reference point for "silt" particles. The 15+ size range indicates the quantity of larger particles present, which contribute greatly to potential catastrophic component failure.
Now, the way the ISO chart lists the "ISO Code" is with a two number system. For example, the approximate rating of new oil off the store shelf would be rated at 20/17. In this two number system, the first number indicates the number of particles that are greater than 5 micron in size. The second set of numbers after the / indicates the number of particles that are greater than 15 micron in size.
Ideally, the lower you can get the two numbers in the ISO chart, the less will be the internal damage inside your engine or hydraulic system.
To ensure that you achieve the most efficient and relative results, it is important to establish and maintain an oil analysis program.
and this
Quote:
In fact of your machine meets 21/17 iso standard and the hydraulic pumps operate at 32 gallons per minute, 8 hours a day, 200 days a year, your actually running more that 635 pounds of durt thru the hydraulic system annually. By improving cleanliness to iso 18/15 you can reduce the amount of dirt in your system to about 80 pounds a year, achieve a 16/13 rating and the amount drops to 20 pounds!
more:-
Quote:
The question is, "what is soot?"
Soot, which is also known as particulate matter, is a normally occuring byproduct of incomplete fuel combustion that takes place in gasoline as well as diesel engines. An engine creates chemical and organic compounds during the combustion of hydrocarbon-based fuels which contain both hydrogen and carbon. These compounds then cluster together in particle form to create soot, which is either released into the air as exhaust or passes through the rings of the combustion chamber and into engine oil. Soot may also come to life as the indirect byproduct of nitrogen oxides (NOx) and sulfur dioxides (SOx) reacting in the atmosphere. Soot’s composition often includes hundreds of different chemical elements, including sulfates, ammonium, nitrates, elemental carbon, condensed organic compounds, and even carcinogenic compounds and heavy metals such as arsenic, selenium, cadmium and zinc.
Diesel engines form soot far more than their gasoline engine counterparts due to the differences in the ways fuel is injected and ignited in diesel engines compared to gasoline engines. In gasoline engines, fuel injection takes place during the intake stroke and is then ignited with a spark. In diesel engines, the process is different. With diesel engines, the fuel is injected during the compression stroke and the fuel is ignited spontaneously from the pressure in diesel engines. The end result is that gasoline engines are much more efficient from an emissions standpoint since the ignition process is better controlled and the air and fuel are more thoroughly mixed allowing for a better and more efficient burn process. This signifigantly reduces the amount of unburned fuel. With diesel engines, fuel injection takes place later in the cycle which makes for a less efficent mixture of the fuel and air. This causes fuel dense pockets in the combustion chamber. The end result is that the diesels exhaust will contain far more unburned fuel than a gasoline engine and which means more soot production than in their gasoline counterparts.
Newer EGR (exhaust gas recirculation) diesel engines will run hotter and produce more soot and acids than previous models of diesel engines. Most engine builders have decided that cooled EGR is the most effective way to reduce combustion temperatures. Small amounts of exhaust gas will be piped to the chambers to displace oxygen; less oxygen means cooler combustion. Before going to the cylinders, some of the exhaust gas heat will be absorbed by the engine's coolant, thus the term “cooled EGR." Federal rules now require diesel engines to produce about 50% less nitrous oxide, or NOx, than current diesels thus the reason for the newer EGR diesel motors. More heat, soot and acid will form during combustion in most of these new EGR diesels, say engineers.
Excessive soot formation in oil occurs from many different things: poor fuel spray patterns, worn out piston rings, clogged or dirty injectors, idling, as well as incorrect air to fuel mixtures. A faulty fuel nozzle may spray more fuel than desired, increasing the fuel-to-air ratio and causing incomplete combustion and soot accumulation, or the air filter may become clogged, decreasing air supply and increasing the fuel-air ratio.
Soot particulates in general are small in size and shape (less than .05 microns). For reference, diesel engine soot particles are about 1/30 the size of a human hair. The individual soot particles aren't much cause for concern because the majority leaves through exhaust but some will end up in the engine oil as it passes the cylinder rings. Once in the engine oil however, soot can cause engine damage as it accululates into larger and larger particles that can cause wear on the internal engine parts like fine grains of sand. Engine motor oil does contain dispersants designed to reduce the likelyhood of this happening but in conditions where soot is much higher (i.e. EGR engines or poor fuel mixtures) the dispersants just can't keep up with the soot build up.
High soot load conditions lead to loss of oil dispersancy as an oil’s dispersant additives are consumed. As dispersancy is lost, soot particles accumulate and form larger particles that build up on engine surfaces.This build up of soot and sludge will eventually slow and impede oil flow. Soot and sludge buildup can also form on oil filters, which over times will block oil flow and allowing dirty oil back into the engine since the engine oil filter can't work when it is clogged or impeded. In addition, high soot levels within a motor oil increase its viscosity, further impeding oil flow and increasing engine wear. Anti-wear additive performance is also affected in high soot conditions as additives are gradually removed from the oil by adsorption to soot particles, leading to increased wear and premature engine failure.
When soot conditions are especially high, carbon particles can form on the piston ring grooves, causing degradation of the oil seal between the ring and cylinder line and abrading the ring and liner. As the gap between the ring and liner increases, combustion byproducts such as gases and unburned fuels blow into the crankcase, a problem known as blowby, eventually causing expanding gases to lose ability to push the piston down and generate the power necessary to propel the vehicle. Horsepower is lost and fuel efficiency decreases. Ring sticking and poor heat transfer from the piston to the cylinder wall can also result.
So - we can see that when we look at suspended soot loadings in diesel engine lubrication oils - we are talking about pumping an awfully large amount of abraisive / corrosive material around and around the engine over the course of an average years operating cycle!
It only makes sense to trry and remove as much of this as possible!
Sub Micron & Centrifugal Filtration is one way and chemicals added to the oil / regular oil changes, are the other!
What a LOT of buyers of these new turbo diesel 4wd's don't realise is how the injectors are fired. Someof them are whats called HEUI (Hydraulic/Electronic Unit Injector).
Something I then found about the HUEI's in 7.3 T/diesels.
Quote:
Actuated Electronically Controlled Unit Injector Fuel System represents one of the most significant innovations in diesel engine technology in decades. HEUI surpasses many of the limitation of mechanical and conventional electronic injectors, and sets new standards for fuel efficiency, reliability and emission control.
and more
Quote:
Hydraulically-actuated, Electronically-controlled Unit Injectors (or HEUI injectors for short) will have a tremendous impact for the good, or not so good, for the foreseeable future.
PowerStroke diesel and Caterpillar powered RV vehicles depend on HEUI systems to deliver the fuel and make these engines run. The HEUI design uses a second high-pressure oil pump and delivers a constant flow of very high-pressure motor oil to gallery passages in each cylinder head. (Pressures between 500 and 3000 psi) When the electric solenoid on top of a HEUI injector is actuated, this high pressure oil is directed into a chamber inside the injector and provides the hydraulic pressure to force an intensifier piston to move downward. The intensifier piston in turn pushes fuel out into the cylinder. Fuel is injected into the cylinder at pressures as high as 21,000 pounds per square inch.
The technology described here is really quite amazing. It permits fuel control that is so precise that, combined with the rest of the system, cylinder performance can be monitored and instructions to each injector modified to make a smooth running engine even when other mechanical factors would make other engines run rough.
In mechanics, it is always true that proper maintenance is essential to good performance. This principle is especially true for HEUI systems. These injectors are EXPENSIVE! Priced in the neighborhood of $300 per injector, a set of 8 injectors along with the labor to change them can cost more than we used to pay for a complete engine 15 years ago. These injectors depend totally on clean oil of high quality, clean fuel and fuel with enough lubrication ability to make pumps and nozzles have a long, dependable service life.
PowerStroke engines pump unfiltered oil from the sump to the high-pressure oil pump and then to the injectors. This means that to not change oil or to do anything that contributes to accumulation of dirt in the engine will subject your expensive injectors to wear and potential damage as particles suspended in the oil get forced into the injectors.
Because the injection system uses unfiltered oil directly from the pan , it makes total sense to use the very best synthetic motor oil after break-in. High quality synthetic lubricants can tolerate much higher temperatures without coking or breaking down. The best synthetic oils also keep the engine clean by being able to dissolve deposits and keep them safely in suspension to be filtered out or removed at drain time. It is a good idea to install a bypass oil filter on these engines. A fine bypass filter slowly filters the oil to remove particles as small as 2 microns. The full flow filter lets particles below 20 to 30 microns stay in the oil. It is the particles between 5 and 30 microns that are responsible for most of the wear on HEUI injectors and engines. Adding bypass oil filtration, in addition to the normal full flow oil filter, will get rid of these small particles, which would otherwise accumulate in the motor oil to become the cause of wear and failures.
more
At the PowerShop we are seeing a few PowerStrokes that are still running well on the original injectors after of hundreds of thousands of miles and good maintenance. We are seeing a growing number of trucks that need major injector and fuel system service between 80 and 120 thousand miles. The money that was saved by ignoring or neglecting needed maintenance on these lower mileage vehicles comes no where near being worth the pain of parting with thousands of dollars for fuel system repairs that could have been avoided.
It is a lot more fun to help RV’ers enhance the performance of a well cared for vehicle than it is to inform someone that they need expensive fuel system repairs.
Do your maintenance!
As you can tell - I'm getting the idea that recirculating soot suspened in the oil thru the injectors on a long term basis is a really bad idea.
This is why I'm so keen on centrifugal filtering...as well as the bypass micron filter!
I'll use quotes for this next bit, but it's a tale I've posted elsewhere so I'm the author of this next bit.
Quote:
In my past, I spent a bit of time as a 'consultant' for the commercial fishing industry & fisheries department, FRDC (Commonwealth Fisheries Research & Development Corporation) etc etc on various commercial lobster boats up and down the WA coast - out to the abrolhos islands etc.... in fact thats HOW i got my commercial sea going time up to get my skippers ticket to be a charter skipper...
With that said i grew up as a kid in the seaside coastal lobster fishing village of Lancelin - bout 72 miles up the coast from Perth.
My ol man was a builder and built the first school house up there as well as a house alongside ours for an old Norwegian fisher named Eric Stokke and his family to live in.
Course living next door to Eric and his kids (who were our ages) - we got to know them well - and he was a REAl old school sea man - escaped Norway during WW2 in a 16 ft fishing boat - sailed it to England past all the German U boats and enlisted in the merchant navy etc..
After the war the Aus govt brought Eric out to help develope the whaling industry here (he'd been on whalers out of Norway) and he helped pioneer some of our early whaling - even with trips down into antarctic waters etc in the very early 1900's!
Anyway - what Eric didn't know about the sea and fishing wasn't worth knowing and of course his kids grew up with the benefit of such a dad, to become to this day - Pro Lobster fishers based outta Lancelin.
The familys always been very successful at what they do - moreso than many other pro lobster familys that have come and gone from the town over the last 100 years!
Anyway - while consulting i got to spend a few weeks at sea with one of Erics sons, Nils skippering their lobster boat. As you do with old mates you've known all ya life - when everyone else bugga'd off at the end of the day - and Nils stayed back at the jetty to service the engines for the next day,I offered to lend a hand doing the oil & Filter changes!.
While I consider myself half knowlegeable about mechanics etc I learned something that day I'll now pass on for what it's worth.
Nils informed me that the family pretty much expect 10,-12,000 hours out of a commercial rated diesel engine in their lobster boats - while other fishers often only get 5-6,000 hours before a rebuild!!
When I pushed as to why this was - he said "clean oil".
He and his brother Carl (and their dad Eric before them) were fastidious about changing oil and filters every time, on time no matter what!
What Nils explained is that the suspended soot in the oil of diesels is what wears them out prematurely, it is corrosive and also abraisive etc...and if you can keep it OUT of the system, then your engines will last much longer, something his family had proven over quite a long time and many engines!.
Something unique to marine engines is they are always under full load....you never run downhill at sea, the load is always constant pretty much unlike cars which only need apply enough HP to maintain momentum on flat ground or none at all downhill - boats must push hard all the time to remain on plane.
Anyway - what Nils showed me was a centrifuge oil filter, that fits on to Fiat disels usually, which - regardless of what engine brand they buy and install - they ALWAYS plumb this Fiat centrifuge filter into the oil pressure line.
Nils dissassembled the filter and got me to clean it out and it's something I've never forgotten. Man it was like carving black butter out of a jam tin, with a pocket knife - the soot & crud built up against the outside walls of the centrifuge was half an inch thick!! (after only 50 hours).
Remember this engine has multiple paper element filters etc, for air and oil - yet all this crud that looks like the sludge you see built up inside engines - is removed from the oil AFTER it's been thru the maufacturers paper filter element.
In truth such paper filters only remove coarse particulate matter above about 20 microns in size and everything smaller just keeps getting recirculated with the oil past bearings and rings etc constantly grinding away at them.
The centrifuge filter is indiscriminate on particulate size - it spins so fast and creates incredible G forces that basically force any size particle to stick to the wall while the liquid oil drains off back into the system.
My suggestion if you want clean oil is this!
Run the normal oil the manufacturer recommends
Run the normal particulate filter, that the manufacturer recommends
Run a sub micron (down to Run a centrifuge filter at full pressure.
Lastly
Run rare earth Neodymium magnets on all oil filters canisters to retain fine ferrous metal particles inside the cannister - to be thrown away at oil change time. (You can find such magnets inside old computer hard drives - they are many many times stronger than a normal magnet).
Those are all mechanical scrubbers / filter methods, that can help keep diesel engine oils clean.
Yes the bitsamissing turbo diesels run dirty because they have a pre ingnition chamber that fires the whole chamber and this is renowned for dirty burns..and much soot!. They more than any other would benefit from the whole treatement, when it comes to filtration.
ONE perhaps valid argument against such high filtration methods as suggested above, is that oil companys add a whole host of chemicals etc (called add packs) to our oils to suspend the soot in the oil so it does not form sludge and gets drained out at each oil change & to counter the formation of corrosive acids etc that form during the combustion process & accumulate in the lubricating oil. Some add teflon particles to improve lubricosity - synthetic oils and synthetic blends add polymers to the oil to get the low base 5 oils to demonstrate base 30 or 40 oils viscosity/lubricosity at high temps and so on.
There is some speculation from the chemical additives crowd, that some of the sub micron filtration and centrifuge actions COULD help to remove the add packs that oil companys add to their oils thus rendering them back to their base oil stock configurations and removing some of the benefits of the add packs.
What one has to ask oneself is, I guess - whether you need that much detergent to keep soot in suspension if your filters are removing it anyway and the oils essentially soot free?
Really speaking these chemicals are added to make up for the poor performance of OEM filtration we get with our mass produced engines!
To my mind the experience of a couple generations of lobster fishers,with diesel engine longevity - and the maxim of kleeping oil clean is proof enough for me!
To give and idea why I say that!
Imagine the cray season is 8 months long & they work every day 8 hours, = ~ 240 x 8 or 1920 engine hours per season...
So if you get 6000 hours from an engine before rebuild - thats 3 seasons or if you get 12000 hours thats 6 seasons, and once rebuilt once they generally discard them for a new engine.
On that basis over 2 generations (30 years each) of lobster fishers - these guys have worn out twice over, 60 years worth of diesel engines replaced every 6 seasons or 6 engines each! Their counterparts would have replaced twice that number!
I think - the combined experience is statistically significant enough to agree that their centrifuge filtration is producong REAL tangible bottom line results to their incomes!
Thats my somewhat "long-winded" take on it!
So by now - likely your begiing to see why I am thinking 3 things:-
1. maybe my LPG conversion is addding more soot than before (but don't know for sure just yet).
2. That the bypass Filtration will help with any luck to reduce the amount of soot (but my initial impressions are the oil is still blackening quicker than previously - even with bypass filtration in place).
3. That maybe Centrifugal Filtration will be able to help remove the sub micron soot that the byapss filter seems to be missing so far!
Well I contacted a local centrifugal filter supplier and we've been chatting quite a lot about what is involved in the plumbing side of it and what filter to get for the F truck and which one for the landcruiser!
Again, these are my words - but I'll use quotes because they are from a local downunder 4wd board
Quote:
Had a good long discussion with the owner in Qld on the phone of the Spinna Centrifuge oil filters that someone here posted the link to on this thread!
http://www.enginecare.com.au/ for thosewho missed it!
He mentioned a lot of "INTERESTING" things I'll try and recall for you all HERE & NOW about the products!
He states unequivocally (and I believe him because I have seen it written elsewhere) that you cannot run both a sub micron bypass filter as well as a centrifuge filter at the same time off your engines oil pump!
It is not because it won't clean the oil twice as well - because it will...
The reason is - that the bypass system is set with spring loaded bypass valves set against the normal oil pressure / volume of your specific engine model type, to hive off about 10% of the pressure & flow from the normal circulation system...and run it thru the bypass and back to the sump...
At that rate - the whole volume of the sump gets scrubbed clean about once every 20 minutes at highway rpm's. Or you clean your sump oil 3 times an hour to put it another way!
But - you do reduce your oil pressure & volume to your mains and big ends bearings etc by that 10% which apparently is within normal wear and tolerance limits for oil pumps and pressures / volumes within an engine. The engineers usually design in %age for oil pressure loss over the life of the engine as wear takes place in the oil pump.
The trubble with running two bypass systems - simultaneously - is that you are then hivivng off (bypassing) 20% of the oil pressure and volume from the mains and bigends bearings, cylinder walls, gudgeons, and so on!
That is too much of a pressure and volume drop for some engines - which start out with low pressure and volume from original design & manufacture.
Some engines such as the early 80 series cruisers - were renowned for big end bearing problems early on, due apprently to low oil pressure and volume - inherrant in the design and combined with bigend bearing shells with too small and too soft retention tabs - they were prone to grabbing and spinning the big end bearing shells inside the bigend caps.
In these engines - unless they have been recalled and modified by Toyota which many have - you don't want to be messing with anything that lowers the oil pressure in a known weak area of the engines design / construction...
The cleaner oil would help to prevent the grabbing problem, but the reduction in oil flow and/or pressure could trigger the problem!
So..
How to keep the oil clean without lowering the oil pressure to the engine?..
I am guessing that it must be possible to plumb an external oil pump, into the oil sump system...perhaps one run by 12V - that cycles a % of the sump oil thru both filters (Sub Micron & Centrifuge) to get it squeakey clean - without reducing the operating pressure and volume of the main engine driven oil pump?
You can easily pic up the pressurised oil for bypass filtering by fitting a "T" piece off the oil pressure gauge fitting at the block but not so easey to get the oil back to the sump! (Unless someone has a bright idea and wants to chime in?).
One of the difficultys plumbing these bypass and centrifuge pumps with the cruisers specifically - is in returning the filtered oil to the sump! From what I'm told, unlike my Ford/Navistar/International 7.3 powerstroke - there is no inspection plug thru the side of the block or sump - to be able to just remove the plug and screw a rubber hose with swaged threaded end fitting into, to return the filtered oil! (If anyone knows different please correct me!).
So... those who do such mods - apparently remove the sump and have a small tube welded on over the top of a hole drilled near the top of the sump pan for the filtered oil return line to connect too!
Well of course the expense of getting the sump pan out of the engine bay to do that modification, is huge because I don't know if it can be done by just jacking the engine and transmission up off it's mounts in the engine bay. Likely there would be sump guards and sub frame cross members in the way etc, in whch case you'd probably have to pull the engine out to do it!
Apparently there is some kind of a self threading tapping fitting that you can buy for this use on the sump in situ, where you grease up a drill bit and drill a pilot hole the size of the oil capilliary you need, then screw the self threading fitting into the hole and it cuts it's own way in and seals all at the same time.
You do it at oil change time, and flush the sump with the sump plug out, to remove any metal drill bit swarf inside the sump from drilling the hole and fitting the connection before refilling with new oil!
I'm trying to see if I can track down such a supply of such fittings from the USA online anywhere at the moment!
(If anyone knows a local supply please advise)!
This would allow us DIY brigade to have a go at our own oil plumbing systems- bearing in mind of course - you can't afford to get it wrong with engine lubricating oil - if a line bursts or hose leaks and all your oil is pumped out onto the road instead of back to the sump - well your engines history most likely if you don't notice the drop in oil pressure and stop before the red idot light on the dash comes on!
Other things I learned in my conversation with the spinna centrifuge filters guy!.
They usually sell the small FM025 spinner cannister to Landcruiser and F 250 diesel 4wd trucks owners...and these retail around the $650 on special at the moment ($730~ish rec retail).
With that said - he has a new modified centrifuge that he can supply FM060 - which has 2 times the size cannister from larger road trains trucks etc, but is fitted with the rotary oil injectors of the smaller FM025 spinner cannister filter to suit the small size engines sump capacity, oil pressure & volume flow of the smaller domestic pickup trucks & 4wds.
The claimed benefit of this is....that the larger cannister has:-
a) More room for sludge to deposit and build up on the walls before needing to be cleaned,
b) The larger diameter cannister gives a bigger swing radius & hence more G's of gravitational force than the smaller cannister, so in effect will separate out even finer particulate matter (soot particles) with less mass far more efficiently than the smaller unit can!
These larger modified cannister units FM060 are available at some $1200 - 1300...for the more serious folks!
So...
I still plan to do both methods, of cleaning the oil in the 80 series cruiser 4.2TD engine...I just don't plan to use the exisiting engines oil pump and start hivivng off (Bypasing) 10% or worse 20% of its oil pressure and volume to do it!
I am thinking of making up a secondary external electric oil pump system, to push a % age of the sump oil thru two different Micron & centrifuge filter mechanisms (plumbed either in parallel or series) and return the oil to the sump - without interrupting the main engines oil pump pressure or volume at all!
I am thinking that the system will also have a secondary / sump reservoir in the way of a holding/storage tank, to hold additional oil to the normal sump volume, such that - whatever % age of the sump oil I'm cleaning at any given time is available within the system to replace watever is removed from the main sump such that the main sump remains full always!
I figure if the main sump remains full, and if the main engine oil pump isn't deprived of any of it's flow or volume - and in addition there is more oil available and it is all scrubbed meticulously clean all the time....then just maybe these diesel engines can be made to get maybe twice the expected operating mileage out of them (1 million miles instead of 500,000!).
I have seen on one of the trucking systems sites, a complete oil treatement system for long haul trucks - that ideally if it could be miniaturised & adapted to our smaller 4wd diesels would be a ripper.
What this system does is have a reservoir tank of new oil (for a 4wd diesel lets say it was a 20 litre tank, assuming like me you have 12 litres in the cruiser or 16 litres in the F truck sump).
What it does - is you set out how many (Kilometers) miles you want to a complete oil change! Lets say - you decide on 5000 km's & you have a 10 litre sump capacity for arguments sake to keep the math simple!
This thing will then be scrubbing away at the oil cleaning it with sub micron bypass and centrifugal filters at the same time - a complete sump oil clean once every 20 minutes of run time, or 3 sump cleans per hour!
It works out that at say 100km's/hour highway speed, you'd do 50 hours driving for your 5000kms to an oil change!
So you want that 10 litres of sump oil fully replaced every 50 hours at 100kph!
What it does is take 200mls of the cleaned sump oil every hour - and pump it to your diesel fuel tank - to blend with your diesel fuel and be burned, and before doing so it injects 200 mls of NEW clean oil from the 20 litre reservoir container....into the engine sump for you!.
By the time you've driven 5000km's in 50 hours @ 100km's/hr andare due for an oil change - the system has continually cleaned your oil for you, 3 times an hour, and done a full oil change for you - and used the cleaned oil to blend with your diesel, to be burned as fuel saving you 10 litres of diesel worth $1.40 a litre or $14.00 in disel fuel cost over that time!
At oil change time - all you do is:-
1.Swap the OEM Filter,
2.Replace Micron Bypass Filter Element,
3.Unscrew the centrifuge filter cannister and scrape out the gunk.
4.Wash the cannister in petrol and put back together!
Your reservoir tank should hold enough for 2 complete oil changes or 10,000 km's, and you just top it up with another bulk drum!
(Ifyou were using synthetic oil and extended oil changes say out to 20,000km's....then obviously you go 2 - 4 timesas far before needing to top up the 20 litre oil reservoir.
You can have a sender in the drum to a guage on the dash so you always know how much oil you have in reserve, a warning light/buzzer if it gets low and you need reminding to fill it up!
Even if it ran out - you could run on your clean sump oil for 5, or 10,000 KM's (or even 20,000km's if your on synthetic & extended oil changes with used oil analysis) before it needed changing!
A self maintaining engine oil system for your engine, that keeps your engine running on new and clean oil the whole time - does your oil changes for you while driving and recycles your old oil as fuel all at the same time - while not robbing the engines oil pump of pressure or flew to achieve this and saving you a pocket full of dough to pay for itself!!
Lastly - the option to plumb an additional engine oil cooler in front of your engines radiator, for the scrubbed oil to be cooled by passing thru before it's returned to the sump, to help keep engine temps down!
I think one is entitled to ask the question...
What is wrong with our auto designers from the likes of Toyota that they don't already have such systems in place on these increasingly technologically advanced engines that require clean oil to be used in a hydraulic system to fire the fuel injectors?
It only makes sense? (And would be much cheaper to do at manufacture rather than as an after market modification).
Sure - you keep an eye on the dash oil pressure gauge and idiot lights, and check the dipstick when you have the bonnet open...but what's wrong with the type of system I'm describing?
Long haulage trucks use it already! It pays for itself in reduced fuel costs, reduced maintenance downtime, increased mileage, increased engine life and so on!
If I can work this out and source the requisit parts at the right price - I might even make these up in kit form for DIY 4wders of diesel and Turbo diesel engined vehicles!
First I need to be able to source the fittings to get the oil back into the sump with out having to remove the engine to mod the sump pan for the oil return....the rest should be a piece of cake!
This brings us to the beginning of my post here, seeking a special plumbing part & the external oil pump...and our discussions this far!
I'm of the opinion that the oil does break downin our heat with oil shearing the PSD's are renowned for, and that - the add packs wear out or are removed by the sub micron filtration - or possibly will be by the centrifuge filter.
For this reason - I'm attracted to the idea - of not running the whole 16 litres of oil in the sump for the whole 5000km's / 3000miles oil change interval.
I'm hoping that If it works I can keep the oil in the sump of the engine - clear yellow like it came from the tin, when you put it in - by continuously scrubbing it clean and simultaneously replacing a portion with new oil as well - so that it doesn't get the opportunity for add packs to break down, wear out, and the viscosity / lubricity wear out, with oil shearing, and so soot levels don't get a chance to increase and be pumped thru the heui injectors multiple times wearing them out prematurely!
This is why I am leaing towards a self replacing system...
The last thing I want to do is run extended oil change intervals - what I'm trying to achieve is a reduced oil change interval - with the engine running it's remaining life on basically clear yellow "new" oil with everything in it's favor - no soot, no acids build up, no worn out add packs, and squeakey clean oil available for hydraulic use thru the HEUI system rather than cruddy black soot laden sump oil, associated with the NORMAL engine arrangement.
Basically my experience so far with the Bypass Micron filter on it's own is that it doesn't seem to keep the engine oil as clean (for hydraulic use) as I would like to be able to keep it!
I hear you asking, why would anyone in their right mind, want to go to such great lengths for a 25 grand pickup?
The answer of course is that we pay so much MORE for the same pickup here downunder, I have over $100,000 Aus (US$80,000) invested in my F truck and it's an integral part of my business towing my charter boat all over this nation - usually more than 1000 miles at a time one way!
To me a couple grand invested in a oil scrubbing / system to keep new clean oil in the sump 100% of the time it operates is a good investement, in not breaking down when I need it most (on a charter).
I guess my perspectives are different to others where the trucks bought with about 12 months beer money, for one of us downunder!
Here - I could buy a house and land for what a F truck costs so the temptation to mod them for longevity is very high!
Anyone wants the cliff notes to all that - just PM me pls
Cheers
I'm a cliff notes type of guy ..but I'll just grant you the validity of your intentions. All good things.
The sump drip method has been used for a decent amount of time to establish its reliability ..and/or to implement sensible safe guards to assure no damage. This isn't a consumer oriented proposed installation.
You are constructing a very elaborate system for which few would consider due to complexity. Keep in mind that you're no longer maintaining an engine ..you're maintaining a "system" that maintains the condition of the oil for the engine. For an example, we went from manually doing the math with gph meters/totalizers to magnetic field flow tubes. We no longer did the math and had all kinds of real time data ..but then got a career of servicing flow tubes and the valves that they controlled
..but that's no reason NOT to do it if you have the resources and motivation.
Building better mouse traps is what BITOG is all about. Anyone can do things in an apparently sensible manner ..and get typical/common results ..however great or pathetic they may be. No one knows what dwells beyond the realm of commonality ..until one steps out of the box and explores.
Please document your installation and share the progress. Share any pitfalls too. They're the most valuable part of any experiment.
