This can be a failing TFI module. Does it have a Ford one? (it is on the distributor).
Should be on heatsink on fender well, least it was on the 5.8 in my '93 Lightning...
If it starts immediately by just touching the throttle, I'd suspect a TPS problem... As long as it runs fine otherwise, I wouldn't worry about it, you'll get a CEL and have drivability issues if the the TPS has major issues...
Fuel pressure will cause drivability issues long before it will cause a starting problem...
