Your vehicle uses ERFS or electronic returnless fuel system and the press. can vary between 35-65 psi. It should hold the minimum press fo at least one minute after shutdown. If there is no schrader valve on a system then you have to open a quick coupler and use an adaptor in line. Do not cut anything and tee in as they are high press. If you smell a strong raw fuel odour after trying to crank for awhile then I would say you have fuel and are weak somewhere else. 4 things needed for a gas engine to run. Fuel, air, spark and compression.
