For about the last 2 years or so my 04 tacoma has had periods when the brake pedal would be hard. The pedal has almost no travel. The truck stops just fine. I press the pedal as hard as I can and sometimes the pedal gives and feels normal but most of the time it does not give. Then for months on end there will be no issues what so ever...!
I replaced the front pads and greased all the parts. Even removed them again a year later and regreased them. none of the brake hoses are hot after use. The fluid appears good and is filled properly.
I did a booster check. I first checked for vacuum leak with carb cleaner. Then I took the hose off and checked it. seems fine. Cleaned the one way check valve. It also appears to work fine. then I pressed the pedal several times then started the engine. The pedal travels about 2" when the engine starts. After warming the engine I press the pedal and each time I do it seems to travel the same distance to the floor. Then holding the pedal down I shut the engine off and count to 30 and the pedal stays put. It may travel down but if it does it's no more than a fraction of an inch.
The only thing I can think to do is change the fluid. Truck has 76K but has done this since at least 45K.
Am I missing something? Thanks!
