- Joined
- Sep 2, 2024
- Messages
- 54
I just installed Speedbleeder check valves on all 4 of my brakes. Installing was straightforward - just removed old one and install Speedbleeder with a little brake fluid dribbling out during the swap.
To bleed it, what I did was (after attaching a bottle with a rubber hose, and it being closed all the way) was turn between quarter and half turn and push the pedal a bunch of time 5-8 times making sure I had plenty of fluid above the ‘low’ line, checking the lines for bubbles (which I had none to begin with), then close the valve.
First I tried doing it with the car turned off, but what happened was while the pedal got increasingly stiffer as I pumped initially and stayed firm throughout doing all 4 wheels, after I turned the car on to check, the pedal almost goes to the floor and feels spongy. Consecutive quick pumps makes the pedal harder but then just goes back to dropping and feeling soft.
I tried then again this time with the car on. It was slightly improved but the pedal still goes too low and it feels soft. The brakes work and is responsive but definitely feels wrong.
Did I miss something?
Also after I put the first one in, it felt way too loose so I wrapped it with 2 turns of Teflon tape for a snug fit.
