OVERKILL
$100 Site Donor 2021
This means remote access to your router is enabled. That's bad. VERY bad.
What if you do want to have remote access to your router?
BTW, even if I disable remote access to my router, ShieldsUp reports that port 443 is open. Not sure why.
You would use a VPN, LogMeIn or something that puts you INSIDE the network, so that it doesn't show up as vulnerable on the outside.
If your router is exhibiting that behaviour I would be suspect of it.
