Ok first off varnish is a precuser to sludge and will affect heat flow to/from bearings.
GP1 oils have better solubility to varnish and sludge BUT they are also not near as good for oxidation resisitance.
A Inhibited GP1 turbine oil tested in ASTM D 943 will be about say 2,000-2500 hours to a 2 TAN a GPII that is inhibited is 9,000 hours or so.
So a GPII will last much longer BEFORE it will start to form varnish and sludge BUT it will.
So using FTIR ot at least a routine TAN MAY tell when to change the oil before any problems start.
No matter the quality of oil if it is ysed to long before change out sludge and varish will form.
Also a routine perhaps every 1,000 hours testing will show things like debris, water, solvents even cross contamination from other oils etc.
So IMHO a GPII changed out at say 8,000 hours will product less varnish and sludge than a GPI changed out at 2,000 hours.
Also oil vedors quality leveals are all over a dispersant additized oil with the correct AO package in a GPII will be the best if monitored and not run to death.
Chevron has a real good one for turbine use with good AO and solvency forgot name but check with them.
As far as system cleaning a GPI will not do to well normally a high aromatic oil is used to flush systems these are like the oposite of a parrifinic oil will low aniline pt and high solvency mobil called there version Mobil sol with aniline points of about 120F.
bruce
