http://products.pollakaftermarket.c...es/ignition-starter-switches-1064/31-164
This is for heavy trucks and one of the terminals is marked GRD on the switch which I just replaced. If you look at the "larger image" of the back of the switch in the link, it is marked GR. I tested the switch I have and the GRD terminal is not connected to anything - not to the metal body of the switch or to any of the other terminals ( BAT, ACC, IGN, ST), in any position of the switch (Off, Acc, Run, Start).
So what is the terminal for?
