Hi guys. I have searched the forums wide and far, but i can´t find a simple answer to this question (i found 1, but that grease is impossible to find)
Im about to put in some tyrolsport C954 bronze alloy bushing that bolts in between the car frame (mild steel) and subframe (alu) to keep it stable.
I know there is a risk of running dissimilar materials together, with corrosion and all that, but i can´t find a simple answer to what i should use? I was about to just use some alu anti seize in between, but someone said a big no no, but not really had any reason why it wouldn´t work, so i thought i ask here first
Ideally it would be rather permanent (or at least as close as possible) doesn´t wash out with water, and has some corrosion resistance or at least can keep the metals seperated so it doesn´t corrode. Its not an issue if its aerosol or wipe on products, as long as it keeps it nice and corrosion free on the car
Hope you guys can help a newbie out and it would be extra bonus points if it was something that was rather easy found in the EU
