I would not do that. Lubricant on the pins can drip down and contaminate the pads. What I recommend is to replace the pins at first sign of wear. You can also sand out the rough spots if they are not too bad.
Spoken like someone who doesnt live with a real winter and road salt?
a tiny dab of any lube that has a good % of solids should be fine. not best idea ever but neither is road salt.
Those are very common, "performance" brake calipers. Well, maybe not common, but not rare. On many models, for instance, Infiniti G35s, the "Sport" package will include this style brake. My brother's Tundra has them as well as my son-in-law's Sequoia and those aren't "sports" cars. Brembo makes brakes like this and others have copied them, including Akebono, for example.What cars are those?
US cars bakes are of the floating caliper design, don't have any "pins" that go trough the brake pads.
What cars are those?....
Interestingly enough....the Akebono ACT976 pads that I put on my Tacoma actually came with a small pack of grease for the pins. I ended up not using it enlue of a bit of antiseize....but still, someone must have thought it was a good ideaIt's cool your choice. !f lubing the pins works for you go for it. The reason I don't grease the pins is not only pad contamination but dirt and grit causing the pads to stick.
The Jetta just used the usual 2-bolt Teves calipers. The pads have a flimsy metal clip to hold them into the pistons and then a spring on the outside pad as “anti-rattle”I'm pretty sure I've worked on at least a couple floating calipers that had similar metal clips for the pads. For the exact vehicles, I'd really have to think about it. It'll probably come back to me, I think my '01 Jetta was one of them.
Not necessarily. There were 2 different calipers used on the MK4's.The Jetta just used the usual 2-bolt Teves calipers. The pads have a flimsy metal clip to hold them into the pistons and then a spring on the outside pad as “anti-rattle”
My RAV4 and Sienna have floating calipers.Toyota and Lexus. The vehicle in question is a 2002 4Runner.
I use the synthetic brake lube on everything. Even the pins get hot by transfer, and that dielectric grease can't handle high temperatures that well. It will bake in and drag a caliper.I use Mission Automotive Dielectric grease on the guide/lock pins and very little CRC synthetic break and caliper grease on the break pad metal tips that contact the pad clips.
