For the Pro Mechanics here, should a person put some grease inside the bushings on new control arms? Thanks.
Control arms rotate constantly at the bushing. As for torquing the bushing bolt with the wheels on and weight on them, good luck with that.Why would you? To lubricate a non-moving joint?
Bushings aren’t supposed to move...this is why you torque the bolts with the weight of the vehicle on the suspension. So that the bushings are locked in place in the middle of their travel.
Grease attacks rubber. Grease would make them more likely to move. Both bad for the bushing.
So, are you trying to prevent corrosion? Use a zinc primer on the bolt and busing sleeve.
Stick to flying airplanes Dude. No pro mechanics crawl under the car to torque the bushing bolts with the wheels bolted on and weight on them.Seriously?
Control arms rotate constantly through the flexing of the rubber bushing, but if you want to believe that it’s because the sleeve rotates on the bolt...well...
Then grease away, dude. Make certain that you lubricate them well. Perhaps even back off the bolt torque so that they can rotate more easily.
Enjoy your new rotating bushing sleeves.
I’m sure that will work much better than flexing rubber.
If you can’t figure out how to torque them with weight on the suspension, you shouldn’t be doing suspension work...but if you believe bushings rotate, well, then. I guess it doesn’t matter.
How do you like to load the suspension.the bolts for the bushings should be torqued with the suspension loaded. You don’t need to crawl underneath the car to do that.
Drive it up on ramps or a floor jack or through the wheel wellHow do you like to load the suspension.
OP, you are dismissing accurate advice. Astro14 and mattd are 100% correct.Stick to flying airplanes Dude. No pro mechanics crawl under the car to torque the bushing bolts with the wheels bolted on and weight on them.
If they are not hacks, yes they do. It is WAY easy if they have a drive-on rack with center jacks . They just roll the car back and forth or some have bearing plates where the tire sit, so the plates move and let the suspension relieve it's "arch movement" side energy holding the car up from it's correct resting ride height. On scissor spreader twin pole lifts you can measure ride height on a lug nut to fender lip and lower the car at ONE suspension point with a jackstand under it get it to it's sitting resting point. It is just part of the correct way to do it. Unless you get very very close to running ride height, bushing life can be reduced drastically.Stick to flying airplanes Dude. No pro mechanics crawl under the car to torque the bushing bolts with the wheels bolted on and weight on them. If the
