Thanks for the reply,
I have no idea what are the condition in Seattle but I find their grease to sticky - Sta Lube - AL complex marine grease. Makes the hub sluggish. I also have doubst that small needle bearings in the planet gears get lubed.
Internal gear hubs are quite popular in the north Europe, and for condition here I use the following recept.
1. Disassemble the right cone - for Nexus/alfine 7,8 special tool is required - add liberal amount of grease - right cone is the most prone for oil leaks use shc 220
2. Smear gears with SHC 220 too
3. Submerge the hub in 75w90 oil or lithium NLGI 000 grease
4. Let dry for 15 minutes
5. Assemble
The hub is ready for next 3years or 10,000km whatever comes first.
Remarks the sealing of nexus 3 is not as good as nexus 7,8/alfine8,11. For nexus 3 I use Calcium sulfonate grease - Total Ceran xm220
5. Assemble
