grease nipple Adjustable ?
Brighton MI,
ok, im confused.. i thought the end of the grease gun is adjustable. So when it leaks out the side you can tighten it up ?
I know that there is that Lock and Lube but... its to big to fit all of my applications.
Yes. I have a lock and lube and it works great for the fittings is works on . .Yes it is bulky.
Yes, the grease gun coupler is somewhat adjustable. You can only turn it down (tighter) until it bottoms out. If it still leaks, then you might have to buy a new one, maybe try to find a better quality one (someone else have experience?). If you cannot get the grease coupler off, you can "open" the adjustment a bit to help release it.
sometimes if you aren't on the zerk straight it will leak out the side. Try changing the angle if the grease gun slightly and see if that helps...
just my $0.02
