Alright, so I got meself a grease gun, rubber flex hose (intended for grease use) as well as a needle to inject the grease into the rubber boots of the ball joints, tie rod ends, sway bar end links etc.
After I assembled everything, I noticed a tricle of grease oozing out of several screw-on points b/t the grease gun, and the needle. I then attempted to tighten all the fittings with a set of pliers. All worked well after this, but when I tried to inject the grease too quickly, little bits of grease started coming out of the fittings (b/t the gun and the needle). So I tried slowing down the rate at which i inject th grease and this helped. I injected about 1/2 a squeeze per joint on the car.
Is this normal? should it take me this long to inject the grease into the fittings? Or should I just tighten the heck out of these fittings for furture use?
Thanks in Advance!!!
