My Dad has a new Cub Cadet Tractor and since the mower is at 25 hours I greased the appropriate items according to the owner's manual. The manual says for the Deck spindle apply 2 strokes minimum or sufficient grease to the spindle shaft, since he has 3 blades there are 3 shafts, I put 8 strokes in each one, could not see any grease oozing out or here any pop sound when the thing is full. Should I add more grease, maybe they hardly greased it at the factory, on my walk behind mower you can see the grease barely ooze out when it is full. When I added grease to the front axles each 1 took 6 strokes of grease, any help would be appreciated.
