Gravley Zero Turn mower shuts off while mowing
Near the beach in Delaware
My neighbor and I bought a couple year old Gravley ZTR. It worked fine for the first month. But now while mowing the engine just stops. It will restart and continue mowing. I printed all the manuals. Its got a couple of safety switches. I don't see a wiring diagram in the service manual.
Ideas?
You didn't mention how old it was.
My Gravely (probably 25 years old or more) had the same issue. There are three little cube-style relays. I replaced them all (they are identical part numbers) and haven't had an issue since. This is a common thing with older units; the relays won't stay latched when you hit bumps or they get too hot.
Its a couple of years old (2022 I think) with 300+ hours.
Something is not making contact. For me it was a loose wire that made it cut off when going over bumps but a bad relay can simulate a key off. I had a relay fail but that only prevented the clutch from engaging.
About the only safety switch that will kill the engine is for the seat and the actual ignition switch. . The others will prevent the starter from cranking. Might be worth starting with reseating the connections for those.
If all else checks out, maybe something is clogging the fuel line that goes down into the tank? Is the key sticking in the start position and not returning to "run" by any chance?
Sounds like the new start-stop technology. My new Outlander does that.. no need to get up, I'm leaving now.....
Hard stop or stutters and slowly (quickly) dies ? If it's a hard stop, it's likely a safety switch or relay like others have said.
