Gravity brake fluid flush
xsr
Hi,
Planning to change my brake fluid on my 2016 Mazda 3 (~80K miles). I might just do gravity as it is much simpler.
Is there any benefit between the gravity method and 2 person or just time savings?
The process seems to be opening the bleeder screws and keeping the reservoir topped up?
I never had much luck or patience for gravity bleeding...I would replace the bleeder screws with speed bleeders. It has a one way check valve built in to prevent air from being sucked in when the pedal is released. A one man job.
Any idea why the OEM does not use them ? - not even that expensive
No revelation there …
They have that decision on hundreds and hundreds of parts …
Yes the balancing act is weighted heavily toward "need to have", over "nice to have."
Unless the Marketing department can convince someone sales would improve.
Probably take pressure from dealerships - like one day - after owning many - I crawled under my new Silverado to find the skid pan was no longer blocking the drain bolt and oil filter !
(Two oil changes for free era)
You can do it yourself, no need for a helper. I posted This Thread in 2016. Get a Orville Redenbocker 30 ounce bottle and a 1/4" I.D. hose. It works well.
One issue that can and does occur is air leakage around the bleeder nipple threads. That's why pressure bleeding is good; it doesn't care. For gravity bleeding or using speed bleeders, it may be worth the effort to remove the bleeder and wrap them with teflon tape first. Of course, the system will be open to air when you do this, though.
I've seen discussion with those using the vacuum bleeders also. Many just apply a bead of grease around the bleeder when loosened to created that slight seal. They wipe off after and spray with brake cleaner.
Many now use the bi-directional scan tools and let the ABS pump do its thing so that unit gets new fluid also.
ChrisFix posted this bottle method years ago.
I've been using it ever since. It almost always has worked great for me. One time I couldn't get it to bleed on the passenger front caliper of my 2002 E150. Had to use the Mighty Vac. Put some silicon brake grease around the top of the bleeder screw to seal the threads. Whatever it costs in tools is almost irrelevant these days compared to paying a shop $100+ per hour. Bleed/change fluid in your brakes every 30K miles and you will never have a problem.
Hi,
The job itself takes so little time if you use what @skyactiv used. You can buy the same thing on Amazon for $20. I have a kit like this and it also includes a bottle that keeps the reservoir full. Makes it an easy one-person job. 90% of the work is lifting the car and taking the wheels off.
However if you know a good way to exercise the ABS on these cars let me know! (I have a 2015 Mazda6)
I use a tube and bottle, something like skyactiv presented. I crack open the bleeder... not fully (1/8 turn?), but enough to have some resistance. During bleeding the pressure forces fluid out, but there is enough resistance to keep the fluid from slurping back in. I've been doing this for 30 years. Simple, easy, effective.
I have speed bleeders on my car, love then. I then use my scan tool tablet to automate the bleed with the ABS pump. I then old school it with my foot at all 4 corners for 3 pump to make sure I have no air in the lines from any sort of pump cavitation. Never saw any, but I still do it that way out of habit.
Hi,
I have had success using pressurized bleeding, gravity and one man bleeder bottle. I like the one man bleed bottle followed by a final gravity bleed.
https://www.walmart.com/ip/Hyper-To...6?classType=REGULAR&athbdg=L1600&from=/search
or
https://www.walmart.com/ip/Brake-Bl...le/17409664457?classType=REGULAR&from=/search
both work great and the best brake pedal feel I had after a bleed was with the stainless check valve bleeder in an old bottle.
The one person method starts at minute 6:30.
The only time I do gravity bleeding is when I replace brake lines and want to get most of the air out of the system before conventional bleeding.
@skyactiv real fancy with that bottle! I, unfortunately am using an old water bottle. Same contraption that has been in use for just over 10 years.
The simple gravity bleed has worked very well for me. I suction out the reservoir, fill with fresh fluid and then crack the bleeders. If I'm feeling motivated, I'll even pump the brake pedal.
