Gravity brake fluid flush
xsr
Hi,
Planning to change my brake fluid on my 2016 Mazda 3 (~80K miles). I might just do gravity as it is much simpler.
Is there any benefit between the gravity method and 2 person or just time savings?
The process seems to be opening the bleeder screws and keeping the reservoir topped up?
With modern ABS systems, using something like a pressurized cap over the master reservoir works well. No need for two people. The tool pays for itself with the first usage. Highly recommended. I use Motive.
I never had much luck or patience for gravity bleeding...I would replace the bleeder screws with speed bleeders. It has a one way check valve built in to prevent air from being sucked in when the pedal is released. A one man job.
Any idea why the OEM does not use them ? - not even that expensive
No revelation there …
They have that decision on hundreds and hundreds of parts …
Yes the balancing act is weighted heavily toward "need to have", over "nice to have."
Unless the Marketing department can convince someone sales would improve.
Probably take pressure from dealerships - like one day - after owning many - I crawled under my new Silverado to find the skid pan was no longer blocking the drain bolt and oil filter !
(Two oil changes for free era)
You can do it yourself, no need for a helper. I posted This Thread in 2016. Get a Orville Redenbocker 30 ounce bottle and a 1/4" I.D. hose. It works well.
  • Like
Reactions: xsr
