Grand Marquis rough idle
Kuwait
Not sure if this fits under this section of the boards, so Moderators please feel free to move.
I used to change my air filters every 3,000 miles, until I installed an air filter life monitor on my vehicles. It's not only cost effective, but rather convenient I must say.
After work today, I pulled up at a service station to refuel my Grand Marquis, and decided to check/adjust hot tire pressures whilst I was at it. I also had some windshield wash concentrate, and thought I might as well top that up too.
As I was checking and adjusting tire pressures, a station attendant came up to me and offered to help. I'm quite obsessive when it comes to who does what to my cars, so I simply gave him a rather decent tip, and thanked him for his offer. Then he proceeded to shove me out the way and started pumping up my tires, as a display of 'appreciation'. Thought might as well let him get on with it, and tell him what the pressures should be for the front (different than rear).
Whilst he was getting along with that, I popped open the hood to top up washer fluid and by that time the guy was done with the tires. He offered to check my oil, and I strictly refused. Tire pressures, alright...checking oil, no thank you.
As I went to get the washer concentrate from the trunk organiser, I got held up by the jack that moved out of place, and did a bit of reorganising. As I was sorting that out, the attendant had taken my air filter out of the housing and started blowing it with compressed air. I never clean my filters, I replace them. This ticked me off, because of the filter life monitor no longer being accurate. So I proceeded to slam the trunk lid and get him to stop. I was going to push the car into the parking spot right next to me, and asked my father to bring me a new air filter before I would start the car.
Unfortunately, he also blew compressed air inside the air box itself, and I think all that dust went through my MAF sensor. I replaced the filter, but the engine idle is very rough now. I bought some Liqui-Moly MAF cleaner and cleaned up the MAF, but it hasn't changed anything. There is no check engine light or anything of the sort. If I pull the MAF connector, idle speed rises and the engine idles better. Any ideas as to what I should do? I think I'm going to have to replace the MAF.
This has really made my day!
I doubt anything happened,just let it settle down a few days and the ECM will relearn the idle mixture.
Pulling the MAF wire or any other ECM connection with the ignition on engine running or not can be dangerous for the part,ecm or both,they are very sensitive parts.
You can remove the MAF element from the housing if you have a set of tamper-proof torx bits. Clean any debris that might be on the sensor element with a q-tip and some MAF cleaner.
Originally Posted By: Falcon_LS
Thanks, Trav! Should I disconnect the battery overnight to reset the ECU?
No it will relearn with no problem.One thing you can do to speed up the learning process is to start the car cold and put it in drive for 3 min at idle then let it idle in park for 3-5 min and repeat a few times.I don't think you have anything to worry about.
After something like this happens folks begin thinking they feel a misfire or roughness until they forget about the incident because they are looking and feeling for it more.
Drive and enjoy that nice Merc.
A little dirt for a minute should not puke a MAF.
You could try taking it off and cleaning it from both sides.
You are smart to use a dedicated MAF cleaner, not just any solvent.
There may be a vacuum leak. Something knocked off or removed, or a manifold /intake leak.
The idle may be high or low when it resets, but never rough.
