Fluctuating rpm at idle
Caribbean
So today i changed my MAF
At idle my rpm keep fluctuating (about +-50 rpm)
The car has been properly tuned up (spark plugs, throttle body, air filter etc)
What can be a cause of this and do note that before my MAF change it had this same problem (i thought the MAF was contributing to this problem)
thanks
Typically when you install a part like that it requires you to drive the car for it to get used to the sensor. It's definitely the case with an IAC sensor
Oh boy another parts swapper. Fire the parts canon! Maybe this will teach you to have proper diagnostics performed. You likely replaced your MAF with an inferior product while simultaneously lightening your wallet.
Clear the KAM and relearn. +/- 50 is not a big deal you shouldn't even be able to see that on tach.
Carbon buildup between the throttle body and the butterfly will cause surging at idle.
Same thing with carbon buildup in the IAC passageway.
Solution ? Take throttle body off the engine and remove all carbon from everywhere.
How you do that ? Throttle body cleaner, Scotch-Brite pad (the white one), acid brush, toothbrush.
