Got 10% better mileage with premium!
Originally Posted By: ravenchris
2007 Sonata, stick. Last week the service manager drove my car and agreed that it pings. He suggested using mid grade gas.
What engine do you have?
I had a ping in my Santa Fe, and I switched brands of fuel and it went away...
The 2.4 should run just fine on 87. I would check into the plugs being the wrong type (heat range). If not that, try switching brands for a few fill-ups. Also check the EGR valve for a lazy diaphragm or plugged hole or the O2 sensor for inaccurate function.
Yes.
Not everyone seems to recognize a ping problem. Cars these days are to insulated to hear the engine ping without the windows down and a barrier or obstruction to reflect the sound back at the driver.
You can check any of that if you like. Its none of them from experience. Fuel brand is always a good idea if its intermittent.
I should add I am running a step colder plug then factory, no effect.
I have had pinging caused by an 02 sensor on my Pontiac 6000, then it returned with a vengeance and turned out to be the EGR. I also had the problem on my partners Escort. Was the 02 sensor on it making it run extremely lean.
A pontiac 6000 is OBD I if that. You can pull the lead off of the O2 on a OBD I and it can take days before you set a DTC. Not the case these days. I'm not aware of any asian brands that even use EGR on 4 cylinders. The current bread are using CVVT system and cam fazing of the exhaust cam to get the same results. With dual 4 wire O2 sensors its much less likely to have a lean condition without setting a DTC, its also more costly to fix since 1 4 wire O2 is tripple the cost of a 2 wire OBD I O2 sensor.
Nope... Within a minute the SES light would come one... Not days my friend... I have actually owned this car and think I would have first hand experience.
Interesting. Other OBD 1 cars I have owned literally took days to register a O2 code.
It would show me the SES light here/there for some unknown reason that I never did sort out, however with the O2 sensor it would always come on right away...
It was a crazy system.. You could disconnect so many things and the engine would continue to run without much mileage variance... Made me wonder why it had a computer and not a Carburetor.
Late 80's and early 90's camaro owners reported similar. Some could disconnect and remove the MAF sensor and the car would be faster on the 1/4 mile with no SES.
Not the 89 IROC I owned but some.
I would think a an ethanol based premium gas would slow done the burning ( ignition ) of the fuel mixed with ethanol ( less mileage ) making for better fuel economy . Just a thought .
10% ethanol yields 4.3% lower heat value so you would expect a drop of only 4.35 in mileage. Difficult to believe a 10% increase using premium instead of 87 octane. If you vehicle is engineered to run on 87 and you are getting 10% better on premium, then something is wrong with you engine tune IMO.
E10 stoichiometric is also lower (numerically) around 14:1 vs 14.7:1 so wouldn't that be a double hit on the mpg?
Less energy and a richer mixture?
I think you mean illuminating the MIL. My 92 Caravan would have codes that never lit the MIL. You only saw them with the right scanner or doing the key (on-off-on-off-leave on) thing and counting the flashes.
