Interesting prospective inside a moving tire.
From the fixed camera on the inside of the rim, we can only see one spot inside the tire, so it's possible that the beads have indeed positioned themselves heavier or lighter in certain areas within the tire accordingly.Don't the beads need to locate themselves 180º from the out-of-balance spot to offset ? These beads are just forced to the outer diameter (once the rotation reaches a given speed).
I have also noted that some roads will produce what feels like an out of balance tire, with certain tread patterns. For example, my CC2's feel off at around 70-75mph on one stretch of road in particular where I live, but take them anywhere else and it's smooth as glass. I have noted this in multiple vehicles with CC2's on them.As a tire engineer, here's what I noticed in the video.
That tire has a tread separation. Notice that when he pries on the crack early in the video, you can see the belt edges. He shouldn't have driven this tire over 50 mph.
On the balancer, if the beads were working as advertised, he should have gotten the same exact reading - he didn't. That says to me the balance beads didn't work!
It's unclear, but it sounds like he didn't balance the assembly before he mounted it on the car.
Here's what he should have done:
1) Mounted the tire on the wheel and balanced it.
2) Marked on the tire where the valve was.
3) Mount the camera, then remounted the tire in exactly the same place, and balance the assembly without the beads.
4) Add the beads and see if there was a change in balance. There should have been an improvement.
5) Add the weights indicated, then repeat the balance. It should be zero and should stay zero regardless of how many times you balance the assembly.
6) Drive the car up to 70 mph, then coast down and note where the vibration is worse. Note the vibration level. There shouldn't be any!
Please note: Vehicle suspensions have a resonant frequency between 50 and 70 mph. That's why the coast down.
