Good websites for checking oil filter compatibility? I have spare FL910S's
Houston, TX
I stocked up on Motorcraft FL910S oil filters, and then we traded the car in. I've had these sitting here for over a year now and want to find out if they will fit on anything else I own. Is there a good website for cross referencing? Random auto parts website list vehicles, but I'm not sure they should be trusted
Go to Wix website. I like to take the number and get Wix filter lookup to translate to a Wix #. Then the Wix # can provide a list of all applications that use that filter, towards the bottom of the screen. In your case the number is Wix 51348.
The Motorcraft FL910S oil filter will fit on MOST riding mowers with a Briggs, Kohler, or Kawasaki engine. The outside diameter, gasket and thread size (3/4-16) match up. You just need to make sure on some that it's not so long that the steering linkage gets in the way.
I found a really good filter for mowers that wasn't ridiculously priced. I bought these so I no longer have to use a 4967 which does slightly block the inlet/dirty oil port but not by much.
A member found these as well.
https://www.amazon.com/HOODELL-Filt...id=pla-4583932712076586&psc=1#customerReviews
