Good afternoon folks Anyone here have a digital antenna recommendation.
Thank You
Thank You
Where do you intend to put the antenna? Attic, wall, roof,etc.?Good afternoon folks Anyone here have a digital antenna recommendation.
Thank You
There are too many variables to answer this. Depends on how far your TV towers are, where you can/will mount the antenna, etc.
That doesn't answer either question.... TV towers could be 5 miles away or 55 miles away and require vastly different antennas. You might locate/mount the antenna on a built-in base behind your TV, in your attic, or on a tower outside and those will be different antennas.Well I have a smart tv and it has antenna cable connect port.
With your situation, a set top antenna will work provided you do not have aluminum siding.Ok: inside antenna, bout 20-30 miles from towers. One tv. Don’t own house so options you mentioned are out.
Wal mart has RCA antenna and few others
The bad thing about a digital tv signal, it either works great or not at all. That's why I miss analog. It never bothered me watching a distant station witha snowy picture.
That’s about what my Lava was hitting from the bay to the antenna farm near Missouri City - very clear and awesome for FM …My mom lives 60 miles north of a local TV station here in Houston.
I installed this outside powered antenna (link below) and she receives the channel clearly on good weather days.
YMMV
https://www.amazon.com/pingbingding-Antenna-Outdoor-Amplified-Mounting/dp/B07DGYGGSF?ref_=ast_sto_dp
