Good Hi Temp grease Question
Louisville, KY
I am swapping ou tht u-joints in my Land Rover's front shaft. I have learned the tend to cook next to the Cat and are prone to failure, so am replacing with greasable ones. They have the needle fitting on one end. What would be a good grease to use in this application (that should be locally available)????
I have Valvoline Dura-blend in the grease gun right now.
thanks for any help,
John
Super High Temp Urea Grease. It is required by Honda service manuals when greasing transmission linkage components because heat will leech a sub-standard grease of oil.
